API to select all text on Skech
pedro_babo
pedro_babo
I'm trying to get all the text on a sketch named “inscricao” on a selection set.
The code is
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        doc = app.activeDocument
        selecttext = ui.activeSelections
        design = app.activeProduct
        components = design.rootComponent.occurrences
        i = components.count
        # limpa selecção.
        selecttext.clear()
        # mostra componentes ja existentes
        if i > 0 :
            for j in range(i) :
                components.item(j).isLightBulbOn = True #mostra Componente
                componente=components.item(j)
                elemento = componente.component
                sk = elemento.sketches.itemByName('inscricao')
                alltexts=sk.sketchTexts
                for text in alltexts:
                    ui.activeSelections.add(text)
        ui.messageBox('selecionado texto')
        cmd = ui.commandDefinitions.itemById('CreateSelectionGroupCmd')
        cmd.execute()
the error is:
Failed:
Traceback (most recent call last):
File "C:/Users/Pedro/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Scripts/SelectText/SelectAllTXT/SelectAllTXT.py", line 27, in run
File "C:/Users/Pedro/AppData/Local/Autodesk/webdeploy/production/50d1a2b00ac928c7781cbca6551e586a5384d498/Api/Python/packages\adsk\core.py", line 14924, in add
return _core.Selections_add(self, entity)
RuntimeError: 3 : invalid argument entity
why active selection is not working on this case?
Replies (8)
BrianEkins
Unfortunately, this is not currently possible.  It should be but there is something missing in the API.  There is a problem in your program that you're getting the sketch text in the context of the component where it needs to be in the context of the root component, which means you would use the createForAssemblyContext method to define the occurrence that you want the text to be in the context of. However, the SketchText object is missing the createForAssemblyContext method.  This is a known issue and is hopefully fixed soon.
To get a better understanding of what I'm talking about you should read this topic in the API User Manual.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-88A4DB43-CFDD-4CFF-B124-7EE67915A07A
Brian Ekins
pedro_babo
Hi Brian many thanks.
Let’s keep this has it gets possible to do with the API.
kandennti
Hi @pedro_babo .
I tried it and was able to make it.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        occs: adsk.fusion.Occurrences = root.occurrences
        if occs.count < 1:
            return
        sels: adsk.core.Selections = ui.activeSelections
        sels.clear()
        occ: adsk.fusion.Occurrence
        for occ in occs:
            comp: adsk.fusion.Component = occ.component
            skts: adsk.fusion.Sketches = comp.sketches
            skt = skts.itemByName('inscricao')
            if not skt:
                continue
            # get proxy
            proxy: adsk.fusion.Sketch = skt.createForAssemblyContext(occ)
            sktTxts: adsk.fusion.SketchTexts = proxy.sketchTexts
            if sktTxts.count < 1:
                continue
            for sktTxt in sktTxts:
                sels.add(sktTxt)
        if sels.count < 1:
            return
        cmdDefs: adsk.core.CommandDefinitions = ui.commandDefinitions
        cmdDef: adsk.core.CommandDefinition = cmdDefs.itemById('CreateSelectionGroupCmd')
        if cmdDef:
            cmdDef.execute()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
BrianEkins
This sample is selecting the sketch. What he needs is the ability to select the text in the sketch.  SketchText is missing the createForAssemblyContext method, so it's not currently possible.
Brian Ekins
kandennti
@BrianEkins .
Thanks for the reply.
I made another sample.
Please forgive me for using some TextCommands, but I can't find any other way.
import traceback
import adsk.fusion
import adsk.core
import json
def run(context):
    try:
        app.documents.add(
            adsk.core.DocumentTypes.FusionDesignDocumentType
        des.designType = adsk.fusion.DesignTypes.ParametricDesignType
        # create Occurrence SketchText
        initOccSketchText(root, 'inscricao')
        # create SelectionSets
        initSelectionSets(root, 'inscricao')
        # select count check
        app.log(u'TextCommandWindow.Clear')
        sels.clear()
        app.log(f'select count : {sels.count}')
        # Reselection using SelectionSets
        execSelectionSets()
        # Dump selected items
        for sel in sels:
            sktTxt = adsk.fusion.SketchText.cast(sel.entity)
            if not sktTxt:
                continue
            msg = f'Text:{sktTxt.text}  '
            msg += f'FontName:{sktTxt.fontName}  '
            msg += f'Height:{sktTxt.height}'
            app.log(msg)
    except:
        if ui:
def execSelectionSets():
    res = app.executeTextCommand(u'Managed.Child 22 0')
    infoJson = json.loads(res)
    txtCmd = f"Selections.Add 57:3:22:{infoJson['entityId']}"
    app.executeTextCommand(txtCmd)
    app.executeTextCommand(u'NuComponents.SelectSelectionGroupCmd')
def initSelectionSets(
    comp: adsk.fusion.Component,
    sktName: str):
    occs: adsk.fusion.Occurrences = comp.occurrences
    if occs.count < 1:
        return
    sels.clear()
    for occ in occs:
        skt = skts.itemByName(sktName)
        if not skt:
            continue
        # get proxy
            continue
            sels.add(sktTxt)
    if sels.count < 1:
        return
    # cmdDefs: adsk.core.CommandDefinitions = ui.commandDefinitions
    # cmdDef: adsk.core.CommandDefinition = cmdDefs.itemById('CreateSelectionGroupCmd')
    # if cmdDef:
    #     cmdDef.execute()
    app.executeTextCommand(u'NuComponents.CreateSelectionGroupCmd')
def initOccSketchText(
    sktName: str):
    txtLst = [
        'hoge',
        'piyo'
    for idx, txt in enumerate(txtLst):
        newOcc: adsk.fusion.Occurrence = comp.occurrences.addNewComponent(
            adsk.core.Matrix3D.create()
        newComp: adsk.fusion.Component = newOcc.component
        skt: adsk.fusion.Sketch = newComp.sketches.add(
            newComp.xYConstructionPlane
        skt.name = sktName
        sktTxts: adsk.fusion.SketchTexts = skt.sketchTexts
        sktTxtIpt: adsk.fusion.SketchTextInput = skt.sketchTexts.createInput2(
            txt,
            2.0
        sktTxtIpt.setAsMultiLine(
            adsk.core.Point3D.create(0, 0 + 10 * idx, 0),
            adsk.core.Point3D.create(10, 5 + 10 * idx, 0),
            adsk.core.HorizontalAlignments.LeftHorizontalAlignment,
            adsk.core.VerticalAlignments.TopVerticalAlignment,
            0
        sktTxts.add(sktTxtIpt)
        sktLines: adsk.fusion.SketchLines = skt.sketchCurves.sketchLines
        sktLines.addCenterPointRectangle(
            adsk.core.Point3D.create(20, 2.5 + 10 * idx, 0),
            adsk.core.Point3D.create(25, 5 + 10 * idx, 0),
I feel that I am able to create a selection set of sketch text only, because after the script is executed, the extrude command extrudes only the text.
pedro_babo
hi @kandennti and @BrianEkins
Many thanks i was able to create the selection set on Design. do you guis have any idia how to do it from Manufacturing?
kandennti
@pedro_babo .
We won't know without looking for it, but the easiest and surest way is to switch workspaces and let it handle it.
import traceback
import adsk.cam
import adsk.fusion
import adsk.core
def run(context):
    ui: adsk.core.UserInterface = None
    try:
        if ui.activeWorkspace.id != 'FusionSolidEnvironment':
            ws: adsk.core.Workspace = ui.workspaces.itemById(
            ws.activate()
        # Perform necessary processing.
        if ui.activeWorkspace.id != 'CAMEnvironment':
                'CAMEnvironment'
            ws.activate()
    except:
        if ui:
pedro_babo
Many thanks @kandennti I will try this
