Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
API to integrate external render engines.
11 REPLIES 11
Message 1 of 12
TrippyLighting
799 Views, 11 Replies
While the Fusion team is doing a great job to improve the internal render engine in Fusion 360 some things simply require the use of an external render engine. To develop visual effects and the optics of my lighting systems () I use the unbiased render engine Indigo Renderer.
There are many good resaons to have an API for external render engines.
  1. Many external render engiens have very extensive material libraries that have taken years to develop Maxwell would be a good example here.
  2. It takes a while to familiarize oneself with a given renderer and develop own materials for ones own purpose and its ineffective having to repeat that effort with an internal renderer
  3. Realistically the F360 internal renderer is unlikely to achieve the speed, features and quality of specialized rendering tools.
  4. etc.
Many 3D packages provide this API in form Python (Blender for example) so this would be a natural fit for F360.
Peter Doering
Labels (1)
11 REPLIES 11
Message 2 of 12
cekuhnen
in reply to: TrippyLighting
Just usable OBJ export already would be nice 😉
I guess they don't want to offer this.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 3 of 12
charegb
We have APIs to support this. Keyshot has already built a plugin based on this.
Bankim
Message 4 of 12
charegb
Message 5 of 12
@charegb
Great. Do we just have to take your word for it, or could you possibly share some details as to how to get some documentation about said API ?
You set this topic to "Solution Provided" but quite frankly you have not provided any solution at all.
A solution would enable someone to write an exporter 😉
Peter Doering
Message 6 of 12
charegb
You don't have to take my word for it, look in the documentation, there is an extensive section for the API. 🙂
http://fusion360.autodesk.com/learning/learning.html?guid=GUID-DE5B70A6-AA7D-439D-8284-2F0382AB6C90
I also gave an example of the Keyshot addin that already does what this idea described so its possible for other rendering products to do it too.
Indigo would need to create a plugin for Fusion now like they seem for have for other Autodesk products.
Cheers,
Bankim
Message 7 of 12
Thanks for the quick feedback. I have created a few small updates for the Indigo exporter/plugin  for Blender and am in process of upgrading my Python skills so I am not entirely unfamiliar with the subject.
I'll dig through the online docs and see where I can get with it.
Peter Doering
Message 8 of 12
charegb
I also wanted to point out the API forum which can provide answers if you get stuck somewhere with the API.
http://forums.autodesk.com/t5/api-and-scripts/bd-p/22
Hope to see you there,
Cheers,
Bankim
Message 9 of 12
Thanks again!
I am stuck already...with only 24 hours a day. I could do with about 12 more. And two more arms.
Wheres the support forum for that 😉
Peter Doering
Message 10 of 12
3Dpcb
I would also like to use Maxwell Render inside Fusion 360. It is absolutely fantastic. www.maxwellrender.com
Please integrate Maxwell Render with Fusion if possible.
Message 11 of 12
PhilProcarioJr
in reply to: 3Dpcb
@3Dpcb
Autodesk doesn't integrate other companies renders, You should contact Maxwell and ask them to make a plugin for Fusion.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 12 of 12
3Dpcb
in reply to: PhilProcarioJr
The sad update to this is, that Onshape is now integrated into Maxwell Render Studio and I got this reply from Maxwell....
Reply from Maxwell Render:
" Hello Peter,
Unfortunately it is not in our planning to develop a plugin for Fusion 360 at this moment. We'll take a look at this. Sorry for inconveniences.
Best wishes,
luisM.
