Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
API - "importSVG" command scaling bug
0 REPLIES 0
Message 1 of 1
kev.ramsay
220 Views, 0 Replies
When I import a SVG file using the API command "importSVG", the scale is incorrect.
I have attached an example script in a ZIP file and a test SVG file will help simulate the problem for you.
To run the script, extract the attached ZIP file to your "Autodesk Fusion 360\API\Scripts" folder.  Then run "ImportSVG" from the "Scripts" tab within the "Tools" / "Scripts and Add-Ins" menu.
After running the script you will be prompted for the SVG file.  Open the attached SVG file and you will see that the square measures 26.458 units instead of 100 units as per the SVG file.
Can this be fixed in the next update of Fusion 360?
Kevin Ramsay
Tags (4)
0 REPLIES 0
