Announcements
API or Script to Renumber tools
kylematthew159
kylematthew159
Hello, I was wondering if it was possible to write a program or script that could change the tool numbers for my tools. I'm well aware the methods build into fusion to accomplish this but I want something I little more powerful. I know the API features on the CAM side are lackluster for the time being, but basically I'm just wondering if this is possible before I start investing time into creating it.
Thanks!
BrianEkins
It's not currently possible.  Nothing associated with tooling is exposed through the API.
Brian Ekins
kylematthew159
That's what I thought but I figured I'd ask. Thanks.
alexpinson5
Is this still the case in 2022?
I'm looking to use a Python script to simply compile all of the tool numbers being used in a file. It looks like I can't access the parameter for the tool in an operation:
I don't need any other info about the tool, just it's number. Worst case I can use the API to generate a setup sheet and then pull the numbers from the HTML file, but I would much prefer if it's possible to access them directly from the API...
BrianEkins
This still is not available. Hopefully soon.
Brian Ekins
alexpinson5
There appears to be at least some level of availability/connection to the tooling info - after playing around a bit more I'm able to use the 'tool_number' and 'tool_diameter' parameters with no issue. I haven't tried anything else, but it is available to some extent.
