API for camera positioning while drawing
For a project I've built my own 'spaceball' like hardware, and am trying to figure out how to make event calls in Fusion in order to support positioning the camera while drawing.   I have a bunch of options on how the device presents itself to the system, right now it's just serial attached.   I was originally thinking of leveraging the API to fire off events, but it seems that having the plugin running constantly may not be exactly a best practices.
Are there any suggestions, or API calls that can be made from outside of Fusion360 to help with camera control?   Should I just treat it as a second mouse?
marshaltu
We have Camara api to let clients be able to position. Unfortunately API doesn't support to be called directly from out-of Fusion 360 process.
The doable solution could be to have plugin run in Fusion 360 and build a connection between your application and the plugin and then let plugin receive events/messages from your application to control the camera in Fusion 360.
Marshal
Marshal Tu
Fusion Developer
You can move the camera programmatically with the API via Application > Viewport > Camera.  You can find a good example of that here. The feasibility of doing that on-the-fly with a plug-in, though, I don't know.
Fusion's orbit shortcut key is shift + middle-mouse button. Maybe you can program your hardware to, when rotated, first move the mouse to center (to make sure it's over the view), hold shift and the middle mouse button, and move the mouse accordingly to give you a 1:1 rotation?
It sounds really interesting though! It'd be great to see your DIY spaceball, if you don't mind sharing. I love homemade interface hardware!
