Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
API feature request: please expand Export object to include other file formats
6 REPLIES 6
moshebar
537 Views, 6 Replies
The UI allows these exports:
  • Autodesk Fusion 360 Archive Files (*.f3d)
  • Autodesk Inventor 2018 Files (*.ipt)
  • DWG Files (*.dwg)
  • DXF Files (*.dxf)
  • FBX Files (*.fbx)
  • IGES Files (*.igs *.iges)
  • OBJ Files (*.obj)
  • SAT Files (*.sat)
  • SketchUp Files (*.skp)
  • SMT Files (*.smt)
  • STEP Files (*.stp *.step)
  • STL Files (*.stl)
Please add them to the API export object.
6 REPLIES 6
BrianEkins
in reply to: moshebar
The reason for the API limitation is that translating to some of these formats is done locally using code that was installed as part of Fusion and the translation of the others is one on the cloud.  The API export only supports the translations that are performed locally.
Brian Ekins
moshebar
in reply to: BrianEkins
Thanks, Brian,
Any plans to include the additional export formats in the API roadmap? such a feature could leverage productivity significantly.
I have a client (F360 user) that asked me for an add-in enhancement that allows *.dxf export.  but I think many users would find batch exporting of the various formats very useful.
goyals
I think Saving the sketch into dxf format is possible. Please take a look at http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-a627026a-27c7-4430-b38a-e51564a4a640.
I think translations to other file formats is possible through forge API. Please take a look at Autodesk Forge API documentation. Thanks.
Shyam Goyal
Sr. Software Dev. Manager
goyals
in reply to: goyals
3d_low
Indeed that would be helpful. I requested it mainly because I draw a lot of parametric sheet metal assemblies. I'll change a few variable and need to re-export all the DXF manually to import them into my nesting software.
It would really make F360 a much more powerful tool
moshebar
in reply to: goyals
Unfortunately, Forge pricing for API access is an order of magnitude more than financially justifiable for my F360 Add-ins.
Regardless, thanks for the link.
