Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
api doesn't allow generating CAM operation "license does not allow generating operations using tool orientation"
3 REPLIES 3
w.mH776F
119 Views, 3 Replies
I am trying to create a tool operation in the CAM Environment througth the api.
I created two operations one with the api one by hand, with the same settings.
But the operation, generated by the api shows the error "Error: Your license does not allow generating operations using "Tool Orientation"." even if its disabled.
Im using Fusion 360 personal use.
Is there any setting in the api, that allows creating operations with the personal use Fusion 360 version?
Best regards
Markus
3 REPLIES 3
kantoku-fusion
in reply to: w.mH776F
Hi @w.mH776F -San.
Unfortunately, the functionality that is restricted by private licenses is limited in both the GUI and the API.
kandennti
in reply to: kantoku-fusion
w.mH776F
I know that the functions are also restricted in the api, too. The error occurs even though I am not using the restricted functions.
