Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
API call to createDXF2DImportOptions fails on some installations
1 REPLY 1
maurizio_mottarellaP385U
98 Views, 1 Reply
Hi Fusion 360,
I have a very strange problem. On some installation of Fusion 360  the call to API function createDXF2DImportOptions fails, returning NULL, apparently without any reason. I made a lot of testing and my code seems correct. The parameters that I pass to the function are correct and my application ( a c++ plug in) normally works.
However I have two installations in which my plug in does not work, with exactly the same binaries.
The functions that fails is
Ptr<DXF2DImportOptions> dxfOptions = importManager->createDXF2DImportOptions(filename, plane);
The version of Fusion 360 is exactly the same, where can be the problem ? Maybe some options ?
thank you in advance
Maurizio
1 REPLY 1
I don't remember the details, but there are some limitations with the translators supported when running a "personal use" license. I don't remember if the DXF translator is included or not and I don't know if the use of a "personal use" license might apply in your case or not.
Brian Ekins
