API and Fusion Manage extension
tillman.boenisch
tillman.boenisch
Hi.
We are using Fusion and the manage extension. With the manage extension you can generate individual item numbers for parts. But the item number is a attribute of the properties. For making the search for a item number easier, we want the item number to be part of the parts name so for instance:
                  The original partname is "Bracket" and this part has the item number PN-000382 and the Revision B
                  Then i want the Part to be renamed to "PN-000382-A_Bracket".
For now we are doing it manually. But i want to make a Python skript to automise this. It is possible to get the name of a document and to change the name with a skript. But is it possible to get the item number and Revision of a part using a python skript and if so how?
Thanks for the help and best Regards
Tillman
kandennti
Hi @tillman.boenisch .
I thought it could be an Occurrence object, but I could not find any properties that would allow it.
I don't have Manage Extension and can't try it out, so I can't confirm it, but I think it probably doesn't provide the functionality.
tillman.boenisch
Hi. I tried with occurence but did not find any matching attribute
Jorge_Jaramillo
Hi @tillman.boenisch ,
I neither have the managed extension, but could you share a copy of a design as an example to try to help you with the solution?
tillman.boenisch
This is a screenshot of an example part. In the Properties the attributes Item Number and Revision is listed. But i think this information is lost when i export the document. But if this helps then this would be great. The manage website also has a script area where the processes are managed. There is also a script describing the item number sequence. But i don't want to screw with it.
Joshua.mursic
Hey @tillman.boenisch, the properties under the General tab in your screen shot are part of Fusion 360 and the items under the Manage tab are part of the Manage extension. Currently I do not believe the API exposes the Fusion 360 Manage Extension, so programmatically changing the part name is probably not possible at the moment. @BrianEkins would know for sure if it is exposed or not. I would also be interested in having the manage extension exposed to the fusion API.
