Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Any method to isolate several occurrences at once?
5 REPLIES 5
en9y37
165 Views, 5 Replies
Hi all!
As long as I know the .isIsolated property in the occurrence object only can be set one by one, so there's no way to isolate several occurrences at once.
Is there any known alternative or workaround to make this possible?
Using the .isLigthBulbOn property is not an option to my purposes, I need the occurrences truly isolated, not just a matter of if they are visible or not.
Thanks in advance!
5 REPLIES 5
kandennti
in reply to: en9y37
Hi @en9y37 -San.
I think that the fullPathName property should be used to call the breakLink method from the shallowest level of the hierarchy, but it was too much trouble, so I forced it to be processed.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        while has_referenced_component():
            occ: fusion.Occurrence = None
            for occ in root.allOccurrences:
                if occ.isReferencedComponent:
                    try:
                        occ.breakLink()
                    except:
                        pass
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def has_referenced_component() -> bool:
    return any([occ.isReferencedComponent for occ in root.allOccurrences])
en9y37
in reply to: kandennti
Excuse me @kandennti , are you sure that response was addressed to me?
kandennti
in reply to: en9y37
@en9y37 -San.
Sorry, I thought you were talking about breakLink.
Please ignore the sample.
kandennti
in reply to: en9y37
@en9y37 -San.
I could not think of any other way than to use the TextCommands.
import traceback
def run(context):
    try:
        exec_isolate(
                root.allOccurrences[0],
                root.allOccurrences[1],
    except:
        if ui:
def exec_isolate(occs: list[fusion.Occurrence]) -> None:
    ui: core.UserInterface = app.userInterface
    sels: core.Selections = ui.activeSelections
    sels.clear()
    [sels.add(occ) for occ in occs]
    app.executeTextCommand(u"Commands.Start IsolateCmd")
    sels.clear()
en9y37
Great @kandennti !!!!
That was a nice walkaround that worked for my needs.
Thanks a lot!!
