Angle value input rotation with select input
rolandas_vegis
Message 1 of 1
rolandas_vegis
When there is angle value input and a select input in the same command the user control which angle input shows on the model doesn't rotate correctly. When trying to rotate it the user control doesn't rotate as it should, instead it only rotates when you stop the rotation (after letting the mouse button go), the value in the dialog updates correctly. If there is something selected, it works as it should.
Attached a video showing the problem.
Replies (0)
