Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Am I allowed to choose the directory that Fusion 360 installs in?
1 REPLY 1
Frenchtoastjack
98 Views, 1 Reply
I just downloaded Fusion 360, and started the installer, assuming that I would be presented with the option to choose the directory of installation, but Fusion 360 proceeded to install on its own. This is a problem, because I only have 4GB of storage on my Boot Drive, but I have over 100GB available on my 😧 Drive. Is there a way I can make Fusion360 install on the latter?
1 REPLY 1
I don't know if it is possible to change installation directory.
An option could be to use a linked directory from boot drive (c:) to the other drive (d:).
Since Fusion 360 is installed in C:\Users\<user>\AppData\Local\Autodesk (*), you can try the following step by step (for windows; I don't know how it could be on Mac):
1. Create the directory d:\Autodesk
2. Run cmd as system admin
3. cd C:\Users\<user>\AppData\Local
4. mklink /J Autodest d:\Autodesk
(*): replace <user> with your username
Then you can try to install Fusion 360.
I hope this could help out.
Jorge Jaramillo
Software Engineer
