Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
airfoil DAT to spline v2.0 sometime is not working
0 REPLIES 0
Message 1 of 1
Maurizio3
145 Views, 0 Replies
Hello, using this script I obtain this answer:
Failed:
Traceback (most recent call last):
File "C:/Users/mauri/AppData/Roaming/Autodesk/ApplicationPlugins/Airfoil_DAT_to_Spline_v2.0.bundle/Contents/Airfoil_DAT_to_Spline_v2.0.py", line 49, in notify
airfoil.Execute(sel0.entity, input1.value, input2.value, input3.value, input4.value, input5.value);
File "C:/Users/mauri/AppData/Roaming/Autodesk/ApplicationPlugins/Airfoil_DAT_to_Spline_v2.0.bundle/Contents/Airfoil_DAT_to_Spline_v2.0.py", line 345, in Execute
point.transformBy(rotationMatrix)
File "C:\Users/mauri/AppData/Local/Autodesk/webdeploy/production/a025d29cc566c591e9a766a22ab936c55abdd11a/Api/Python/packages\adsk\core.py", line 13956, in transformBy
return _core.Point3D_transformBy(self, matrix)
RuntimeError: 3 : invalid argument matrix
0 REPLIES 0
