Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
additional info on RowCommandInput
2 REPLIES 2
Digi-D
247 Views, 2 Replies
Trying to put together a quick interface. Starting with Command Inputs API Sample API Sample Example.
I am trying to implement RowCommandInput.
# Create single selectable button row input
            buttonRowInput = tab1ChildInputs.addButtonRowCommandInput(commandId + '_buttonRow', 'Button Row', False)
            buttonRowInput.listItems.add('Item 1', False, 'resources')
            buttonRowInput.listItems.add('Item 2', False, 'resources')
I was able to search documentation for  addButtonRowCommandInput method and figure out the parameters we are passing in. However, I can't find information on the list items and what gets passed with the add method. Is there a handy python way to figure this out or additional online documentation that someone can point to.
Thank you.
2 REPLIES 2
marshaltu
in reply to: Digi-D
Please refer to the following link for the help of ListItems.add.
http://fusion360.autodesk.com/learning/learning.html?guid=GUID-36B1FFB5-5291-4532-8F11-90E912769B34
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
marshaltu
in reply to: marshaltu
It seems that the link will direct to home page of API help.
Please browse to listItems by Programming Interface -> Fusion 360 API Reference Manual -> Objects -> ListItems.
Marshal
Marshal Tu
Autodesk, Inc.
