Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Adding toolbar tab with own add in
1 REPLY 1
n.michiels
177 Views, 1 Reply
Hello All,
I want to add a new toolbar tab in the design workspace with python.
I am able to do so with the example code: https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-
In this example they add the existing extrude command to the new toolbar tab.
I want to add my own add-in to this new toolbar tab. I changed the code a little to insert my own add-in.
My add-in is show in the new toolbar tab, but it is not responding when clicking on it.
Can somebody help me with this?
Thank you!
1 REPLY 1
kandennti
in reply to: n.michiels
Hi @n.michiels .
The 'CSVBomAddInMenuEntry' command was not defined, so it did not even show up for me.
I used 'Extrude' instead and it did show up and I could press it.
        # For this example, we are adding the already exisiting own add-in command into a new panel:
        cmdDefinitions = ui.commandDefinitions
        # anotherExtrudeCmd = cmdDefinitions.itemById('CSVBomAddInMenuEntry')
        anotherExtrudeCmd = cmdDefinitions.itemById('Extrude')
        runningTabbedToolbar = ui.isTabbedToolbarUI
