Announcements
Adding new workspace not working
I am trying to add a new workspace but it does not seem to work.
What am I doing wrong? No error but no new workspace appears in the list.
import adsk.core, adsk.fusion, adsk.cam, traceback
import random
def run(context):
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        cmdDefinitions = ui.commandDefinitions
        anotherExtrudeCmd = cmdDefinitions.itemById('Extrude')
        #Random ID so I dont have to remove old before adding new
        ID1 = str(random.randint(0, 9999999999))
        ID2 = str(random.randint(0, 9999999999))
        ID3 = str(random.randint(0, 9999999999))
        nWorkspace = ui.workspaces.add("DesignProductType", ID1, "New Workspace", "")
        nTabs = nWorkspace.toolbarTabs
        nTab = nTabs.add(ID2, "New Tab")
        nPannels = nTab.toolbarPanels
        nPannel = nPannels.add(ID3, "New Pannel")
        nPannel.isVisible = True
        nControlls = nPannel.controls
        nControll = nControlls.addCommand(anotherExtrudeCmd)
        nControll.isVisible = True
        nControll.isPromoted = True
        nControll.isPromotedByDefault = True
    except:
        if ui:
            print(traceback.format_exc())
Got the exact same problem. The workspace is being added (as it says that a workspace with the same ID already exist when running the add-in the second time) but not appearing in the environment list.
The only Add-In I know of that is adding a new workspace is joinerCAD, but its Windows only so I cant download to see how they are doing it.
It might be worth having a look If you have the right OS.
Thank you for the suggestion!
Unfortunetaly, JoinerCAD doesn't add a new workspace, but adds a new toolbar instead. Apart from that, their source script is locked, so you simply can't view their code.
Thanks anyway! Much apreciated.
BrianEkins
I believe with the change to the new UI, some changes were made to workspaces and the API hasn't been updated to fully support customization of the new UI.
Brian Ekins
That would be a little disappointing, but at least it could be an explanation. I've read another post that was very recent with this issue. The documentation that I found of cases where it did function, are a little older.
