Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Adding Motion Link to the Fusion 360 API
2 REPLIES 2
rbin_robotik
319 Views, 2 Replies
Motion Link for the Joint API is a great feature on Fusion 360. However, it is not available on the Fusion 360 Programming Interface. I understand that it may be tricky to make Motion Link available for the API, but I am wondering if there could be a simple method/property addition to the Joint-type classes, which gives information about the linked joint. This option, as it is, will also be extremely helpful.
For your reference, there is also a 4-year-old forum post asking the availability of Motion Link for joints on the Fusion 360 Programming Interface.
Thank you!
Labels (1)
2 REPLIES 2
Fusion 360 Manage (not the same as) Fusion 360
lenAWCUZ
in reply to: rbin_robotik
Plug-in developers like ProtoTech Solutions need an API for Motion Study in order to export PDFs with animated 3D objects. Please, Autodesk, help them out!
