Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Adding methods for Parameters: Is it possible?
2 REPLIES 2
mnoreke
181 Views, 2 Replies
Hello!
I have a project where I need sets of parameters that are dependent upon a master variable to select the version of the data.
Example:
Variable Name Normal Value Alternate 1 Alternate 2
Variable NamePrimary Data SetAlternate Data Set 1Alternate Data Set 2
Scale10.330.25
Scale Index123
Length10033.325
Material Thickness532
What I would like is to create a few method signature that can be used in the parameters window similar to these:
CalculateScale(Scale, 100); // For Length
SelectScaleValue(ScaleIndex, [5,3,2]); // For Material Thickness, array of values
Is this possible, and if so, where do I look for reference materials on creating such methods?
Thanks in advance for any and all help!
CAD Enthusiast
Former Developer
2 REPLIES 2
BrianEkins
in reply to: mnoreke
I'm not sure I fully understand what you want to do but Fusion doesn't support defining custom functions to use with parameters. You're limited to the set of built-in functions.
Brian Ekins
mnoreke
in reply to: BrianEkins
That answers my question Brian. I guess I need to create an app that manages my data set and sets the variables as needed when I change scale.
Thanks. 🙂
CAD Enthusiast
Former Developer
