I've written an add-on that adds a button to the UI that when pressed prompts the user to select any number of surface bodies (ideally patches) and click okay to extend all the edges of the patches then thicken them. My issue is once the command is executed the function extendAndThickenPatch runs once and then the commandInputs list is cleared and I lose the ability to call on all other selections the user has made. This add-in works perfectly if the user selects only 1 patch but any more and it stops after a single round of the for loop in class ExtrudePatch, printing an out of range error. Attached is the plugin as well as the bracket part I've been using to test it. Is there a change I can make to iterate through all the selected items and make the changes to them via the multi selection without the inputs list clearing?
Code:
from typing import Union
import adsk.core, adsk.fusion, adsk.cam, traceback
from types import TracebackType
import subprocess
import os, os.path
import sys
handlers = []
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
# Get the CommandDefinitions collection.
cmdDefs = ui.commandDefinitions
work_space = ui.workspaces.itemById('FusionSolidEnvironment')
# Get toolbar
tb_panels = work_space.toolbarPanels
global TB_PANEL
TB_PANEL = tb_panels.itemById('mm_Panel2')
if TB_PANEL:
TB_PANEL.deleteMe()
# Create extra toolbar widget for Nester and Slicer
TB_PANEL = tb_panels.add('mm_Panel2', 'Mold Maker', 'SelectPanel', False)
addins_toolbar_panel = ui.allToolbarPanels.itemById('mm_Panel2')
patchAndExtrudeButtonDef = cmdDefs.addButtonDefinition('Patch and Extrude Tool',
'Foundrylab Patch and Extrude Tool',
'Generates tube blockers for mold making',
'resources/step1')
buttonpatchAndExtrudeCont = addins_toolbar_panel.controls.addCommand(patchAndExtrudeButtonDef, 'MoldMaking')
# Connect to the command created event.
buttonpatchAndExtrudeCont.isPromotedByDefault = True
buttonpatchAndExtrudeCont.isPromoted = True
#When pressed cast to task running class
patchAndExtrudeCreated = patchAndExtrudeButtonPressedEventHandler()
patchAndExtrudeButtonDef.commandCreated.add(patchAndExtrudeCreated)
handlers.append(patchAndExtrudeCreated)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class patchAndExtrudeButtonPressedEventHandler(adsk.core.CommandCreatedEventHandler):
def __init__(self):
super().__init__()
def notify(self,args):
#ui = None
cmd = adsk.core.Command.cast(args.command)
cmd.setDialogMinimumSize(100,100)
# Get the CommandInputs collection associated with the command.
inputs = cmd.commandInputs
# Create value input.
selectInput = inputs.addSelectionInput('PatchTool','Select patches to extrude', 'Select a patch')
selectInput.addSelectionFilter(adsk.core.SelectionCommandInput.SurfaceBodies)
selectInput.setSelectionLimits(0)
# Connect to the execute event.
onExecute = ExtrudePatch()
cmd.execute.add(onExecute)
handlers.append(onExecute)
"""try:
bodySel = ui.selectEntity('select surface entity', 'SurfaceBodies')
if bodySel:
extrudePatch(bodySel.entity)
except:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))"""
class ExtrudePatch(adsk.core.CommandEventHandler):
def __init__(self):
super().__init__()
def notify(self, args):
design = app.activeProduct
eventArgs = adsk.core.CommandEventArgs.cast(args)
# Grabs list of all commandInputs
inputs = eventArgs.command.commandInputs
# Selects the selectionInputs command input from commandInputs. commandInputs should be size 1
selectionsList = inputs.item(0)
# Number of patches selected by user
count = selectionsList.selectionCount
for num in range(count):
try:
patch = selectionsList.selection(num).entity
extendAndThickenPatch(patch)
except:
def extendAndThickenPatch(patch):
inputEdges = adsk.core.ObjectCollection.create()
# Get all the edges of this patch surface
patchEdges = patch.edges
# For every patch edge add it to inputEdges to extrude
for edge in range(patchEdges.count):
inputEdges.add(patchEdges.item(edge))
distance = adsk.core.ValueInput.createByReal(1.1)
# Get the root component of the active design
rootComp = design.rootComponent
features = rootComp.features
extendFeatures = features.extendFeatures
extendFeatureInput = extendFeatures.createInput(inputEdges, distance, adsk.fusion.SurfaceExtendTypes.NaturalSurfaceExtendType)
extendFeatureInput.extendAlignment = adsk.fusion.SurfaceExtendAlignment.FreeEdges
extendFeatures.add(extendFeatureInput)
thickenFeatures = features.thickenFeatures
inputSurfaces = adsk.core.ObjectCollection.create()
inputSurfaces.add(patch)
thickness = adsk.core.ValueInput.createByReal(-0.002)
thickenInput = thickenFeatures.createInput(inputSurfaces, thickness, False, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
thickenFeatures.add(thickenInput)
def stop(context):
ui = None
try:
except:
if ui:
