Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Adding both Find In Browser + Find In Window to a menu causes one to disappear
2 REPLIES 2
jade.fink
235 Views, 2 Replies
I wrote an extension to make it possible to assign shortcuts to a bunch of Fusion commands including Find In Browser. Recently a user asked me to add Find In Window, which I promptly added and tested the extension. Unfortunately once I add Find In Window to the panel, Find In Browser disappears!
This seems like a Fusion bug. To reproduce: install the addin from https://github.com/lf-/ShortcutItPy/tree/bug (note the "bug" branch), then note that in the Tools panel, in Shortcut It, Find In Browser is missing. Delete the line "('FindInWindow, './findinbrowser')," from the source file, reload the extension and Find In Browser will reappear.
It would be equally acceptable to me if Fusion had all of these things in a menu or otherwise possible to add shortcuts for without requiring an extension, but that's maybe too much to ask 🙂
2 REPLIES 2
goyals
in reply to: jade.fink
I just clone bug repo from git but unable to see the problem. Please take a look at screenshot.
Shyam Goyal
Sr. Software Dev. Manager
jade.fink
in reply to: goyals
I have no idea how that could be happening, because it was happening on my two Windows machines. Maybe it's a Windows only bug? Not sure.
Either way, this is what I'm seeing on Windows 10.
