Announcements
addFloatSliderCommandInput Slider Increment
ebunn3
ebunn3
I see that there is a way to set the spinStep for a slider but there does not appear to be a way to set something similar for the slider itself.  Is there a way to set the sensitivity of the slider so it increments a lessor amount when using the slider.  SpinStep does not appear to affect this slider behavior at all.
Eric
kandennti
Hi @ebunn3 .
I tried it too.
It changed the properties but did not change the behavior.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
_app: adsk.core.Application = None
_ui: adsk.core.UserInterface = None
_handlers = []
_sliderIpt: adsk.core.FloatSliderCommandInput = None
_dropDownIpt: adsk.core.DropDownCommandInput = None
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: adsk.core.CommandCreatedEventArgs):
        # adsk.core.Application.get().log(args.firingEvent.name)
        try:
            global _handlers
            cmd: adsk.core.Command = adsk.core.Command.cast(args.command)
            # inputs
            inputs: adsk.core.CommandInputs = cmd.commandInputs
            global _sliderIpt
            _sliderIpt = inputs.addFloatSliderCommandInput(
                'sliderIptId',
                'Slider',
                'mm',
                0.0,
                100.0,
                False
            unitMgr: adsk.core.UnitsManager = _app.activeProduct.unitsManager
            _sliderIpt.spinStep = unitMgr.convert(1, unitMgr.defaultLengthUnits, unitMgr.internalUnits)
            global _dropDownIpt
            _dropDownIpt = inputs.addDropDownCommandInput(
                'dropDownIptId',
                'Slider Step',
                adsk.core.DropDownStyles.TextListDropDownStyle
            ddItems = _dropDownIpt.listItems
            ddItems.add('1', True, '')
            ddItems.add('5', False, '')
            ddItems.add('10', False, '')
            ddItems.add('20', False, '')
            # event
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onStepChanged = StepChangedHandler(_dropDownIpt)
            cmd.inputChanged.add(onStepChanged)
            _handlers.append(onStepChanged)
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class StepChangedHandler(adsk.core.InputChangedEventHandler):
    def __init__(self, ddIpt: adsk.core.DropDownCommandInput):
        super().__init__()
        self.input = ddIpt
    def notify(self, args: adsk.core.InputChangedEventArgs):
        if self.input != args.input:
            return
        global _dropDownIpt, _sliderIpt
        step = float(_dropDownIpt.selectedItem.name)
        _sliderIpt.spinStep = step
        global _app
        _app.log(f'Slider SpinStep:{_sliderIpt.spinStep}')
class MyCommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: adsk.core.CommandEventArgs):
        adsk.terminate()
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        cmdDef: adsk.core.CommandDefinition = _ui.commandDefinitions.itemById(
            'test_cmd'
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition(
                'test_cmd',
                'Test',
                'Test'
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
BrianEkins
I suspect this isn't supported internally by the float slider. When I use some Fusion commands that have float sliders their values aren't nice even values. I'm guessing that Fusion determines the increment based on the number of pixels the slider currently spans and that's what you get.
Brian Ekins
ebunn3
Thanks all for the support.
Eric
