Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Add-On cloud saving feature.
1 REPLY 1
macmanpb
129 Views, 1 Reply
Is it possible to save created preferences data by an Add-on into the user's fusion360 cloud? The reason behind that is, I want that the user has access to the add-on preferences on all his fusion360 instances.
1 REPLY 1
BrianEkins
in reply to: macmanpb
This would be nice but it's not currently possible. Ideally, there could be custom preferences you could save using the API and Fusion would take care of saving them and syncing them to other machines the user uses. I know it was talked about a long time ago but I doubt it's likely to happen in the near future.
Brian Ekins
