Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Add link to make menu
1 REPLY 1
kyleparisi
149 Views, 1 Reply
Hello I was wondering how I might be able to add https://buildapart.io to the Fusion 360 "Make" menu area.  If it requires development work I'd be more than happy to do it.
1 REPLY 1
goyals
in reply to: kyleparisi
You need to write a new add-in to achieve that
1. This article explains how to add a new add-in Fusion
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-9701BBA7-EC0E-4016-A9C8-964AA4838954
2.  This article explains how to add a new command through an add-in in Fusion
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-e5c4dbe8-ee48-11e4-9823-f8b156d7cd97
3. This article explains how to create a plaette control in a command. Palette control is a browser control and can load the website page.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-F0068478-49F0-4E5E-9BAD-3116D8FCBCAF
Feel free to reach out if you have follow up question.
Shyam Goyal
Sr. Software Dev. Manager
