Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Add-ins not visible
2 REPLIES 2
retired1
149 Views, 2 Replies
Add-ins not visible
Selected spur gears from the menu in utilities. Selected run. Cannot see any icon on my design . Also installed FM gears and it appears at the bottom of the create menu. Any suggestions would be appreciated. Have latest ver. of 360 installed.
Thanks Jeff
2 REPLIES 2
retired1
in reply to: retired1
Figured it out. When creating the add-in, you need to name it exactly as the add-in appears. i.e you cannot re name it .
BrianEkins
FYI, it is possible to rename add-ins, but the folder, the main py file, and the manifest file all need to have the same name.
Brian Ekins
