Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Add-ins grayed out after Update!!
9 REPLIES 9
Message 1 of 10
macmanpb
787 Views, 9 Replies
Why Add-Ins in manufacture workspace are grayed out.
How can i bring them back to work?
9 REPLIES 9
Message 2 of 10
adam.nagy
in reply to: macmanpb
I'm told it's supposed to be fixed in an update planned to be coming out on February 3
In the meantime this could be a possible workaround for running the commands:
https://modthemachine.typepad.com/my_weblog/2020/01/run-commands-from-the-text-commands-panel.html
Adam Nagy
Autodesk Platform Services
Message 3 of 10
macmanpb
in reply to: adam.nagy
@adam.nagy Thank you for that workaround. I will that submit to my customers if Feb3 is to far 😉
Message 4 of 10
goyals
Just to update the people watching this thread and facing this issue, We might deliver hot-fix early hopefully by tomorrow. Thanks for your patience.
Shyam Goyal
Sr. Software Dev. Manager
Message 5 of 10
macmanpb
in reply to: goyals
@goyals , @adam.nagy  That would be awesome. Thanks for the support!
Message 6 of 10
TimPaterson
To boil down the work-around, you can start an add-in using this statement in a Python text command:
adsk.core.Application.get().userInterface.commandDefinitions.itemById("<command-id>").execute()
where <command-id> is the command id string for the add-in. Since I wrote my own add-in, I know what mine is. To list them all to find the one you want, paste in this text command:
for cmd in adsk.core.Application.get().userInterface.commandDefinitions: print(cmd.id, " name: ", cmd.name)
Message 7 of 10
goyals
in reply to: TimPaterson
Just to update , hot fix is deployed last night. Please try once to verify whether problem is resolved on your side or not. Thanks.
Shyam Goyal
Message 8 of 10
macmanpb
in reply to: goyals
@goyals  Thank you! DragKnife is working as expected.
Message 9 of 10
TimPaterson
in reply to: goyals
How do I get the hot fix?
Message 10 of 10
adam.nagy
Fusion 360 is supposed to update automatically
Adam Nagy
