Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Add-In trouble
2 REPLIES 2
brad.bylls
132 Views, 2 Replies
Add-In trouble
I have added a video to explain my problem and the code to go with it.
The code works when I create something in F360 but if I bring in a step file from a website it does not.
Brad Bylls
2 REPLIES 2
BrianEkins
in reply to: brad.bylls
I didn't try running your code, but from watching your video, I can see in the first case, the design is set to capture the design history, and in the second case, it is not. In the imported file, right-click on the browser's top node, choose the "Capture Design History" command, and then see if it works.
Brian Ekins
brad.bylls
in reply to: BrianEkins
Thanks Brian.
Adding the design history solved the error problem.
Brad
Brad Bylls
