[Add-In] Check computer specifications
CheckComputerSpecs is an add-in that checks computer specifications against system requirements recommended by Autodesk for Fusion 360. It works on Windows and macOS.
It scans your computer for information about CPU, GPU and memory modules. Then it compares the values with the tables in the system requirements webpage on the Autodesk website.
Codes and information are posted on GitHub: https://github.com/JeromeBriot/fusion360-check-computer-specifications
Post comments in this discussion. Report bugs on the Issues page of the GitHub repo if possible.
Thank you.
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
