Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Add conditions to suppress (or activate/deactivate) timeline features?
2 REPLIES 2
david.lantier
369 Views, 2 Replies
I would like to execute some "timeline features" (ie. extrude, plane, ...) under a condition (ie. paramX = N, but also according context on execution of timeline), in order to get more flexibility on some projects (as Inventor if I'm right). One idea is to super seed at any "timeline features" by a condition that could "suppress features" or "unsuppress feature" then operation, using python or c++.
Is this possible? Or is this coming soon in Fusion? Or is there is already a solution?
Many thanks,
David
2 REPLIES 2
BrianEkins
in reply to: david.lantier
The API supports accessing all existing features and you can suppress or unsuppress them.  Using that capability you can define whatever logic you want within a program that will suppress features as needed.
Brian Ekins
Thanks for this advice, I will take time to investigate this way!
