Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Activate a folder in the CAM environment
2 REPLIES 2
Joshua.mursic
206 Views, 2 Replies
I am really struggling with the lack of functionality of the CAM API.
I have created a library inside of Fusion with several projects that have different geometries and CAM Setups saved inside of them. I have been able to open these documents and import in the CAD models easily, but have been unable to grab objects from the CAM environment.
I have tried to save the CAM setups as Templates and then import them into the new project with some success, but I need to import the templates into a specific folder in the new projects new setup, and I do not see any functionality to activate a folder to do this.
cam.setups.item(0).folders.item(0).isSelected = True
This does not work as the 'isSelected' property appears to be read only.
I have also tried to open the template document and using text commands, have been able to copy the entire Setup, including folders and toolpaths. However when I navigate over to the new project, I have no way of selecting the RootSetup so that I could use a text command to paste the copied Template.
# Targets and copies the first setup in the template document
template = app.documents.open(TEMPLATE_DATAFILE,False).products.itemByProductType('CAMProductType')
templateCam = adsk.cam.CAM.cast(template)
templateCam.setups.item(0)
app.executeTextCommand('Commands.Start IronCopy')
# Reactivate the CAM enviroment in new document
app.documents.open(NEW_DOC_DATAFILE,True).activate()
ui.workspaces.itemById("CAMEnvironment").activate()
camProduct = app.activeDocument.products.itemByProductType('CAMProductType')
cam = adsk.cam.CAM.cast(camProduct)
setups = cam.setups
# Trying to paste to copied Setup but 'cam.setups'
# does not target the setups  object in the ui and thus
# the paste does nothing.
app.executeTextCommand('Commands.Start IronPasteCommand')
are there any text commands to select items in the UI? like the image below
Lastly I tried to use the API and text commands to create a new setup from scratch, but I still ran into the problem where I could not target a newly created folder. I used the text command:
app.executeTextCommand('Commands.Start IronFolder')
to create a new folder but the new folder is not the active object, and so when I create or insert toolpaths using templates, the instead fall under the Setup on the same level as the Folder, and I instead need them inside the folder.
Thanks in advance for any insight.
Kind regards,
Josh
2 REPLIES 2
kandennti
in reply to: Joshua.mursic
Hi @Joshua.mursic .
You can choose to use "ONK" as described here.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/can-we-select-a-setup-programmatically/m-p...
Can't you select it this way?
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
import adsk.cam
from urllib.parse import quote
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        doc = app.activeDocument
        # products = doc.products
        # cam = adsk.cam.CAM.cast(products.itemByProductType("CAMProductType"))
        # ObjectPaths.Onk
        onk = u'ONK::CmpInst={}/Cmp={}/{}/'.format(
            quote(doc.name),
            quote(doc.name),
            'Setups=1')
        app.log(onk)
        # select setups
        app.executeTextCommand(u'Commands.Select {}'.format(onk))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
To check the "ONK", select the element to be checked in advance and use this command from the add-in I have created and published, which will be output to a text command window.
https://github.com/kantoku-code/Fusion360_Developers_Small_ToolKit
Joshua.mursic
in reply to: kandennti
Amazing! Thank you so much @kandennti, I have learned so much from your posts. That is working perfectly.
