Accessing Appearance Thumbnails
nnikbin
nnikbin
I would like to fill a DropDownCommandInput whose DropDownStyle is LabeledIconDropDownStyle with the names and thumbnails of all appearances available in a library.
Iterating through appearances and filling the names is simple but the difficult part is accessing the thumbnails of appearances.
I know that adsklib files are zip archives and appearance thumbnails are inside them as png resources. For example the following picture shows part of the contents of an adsklib file whose extension has changed to zip:
Is there any simple way to access these thumbnails and use them in a DropDownCommandInput?
kandennti
Hi @nnikbin .
The icon is created by extracting the png file from the zip file.
# Description - Material Thumbnail Test
# Fusion360API Python script
import adsk.core
import adsk.fusion
import adsk.cam
import traceback
import re
import io
import zipfile
import pathlib
import shutil
from PIL import Image
_app = None
_ui = None
_handlers = []
def getAdsklibPaths() -> list:
    app: adsk.core.Application = adsk.core.Application.get()
    materialPath = pathlib.Path(
        app.executeTextCommand(f'Materials.MaterialLibraryPath'))
    adsklibPaths = [p for p in materialPath.iterdir()
                    if p.is_file() and p.suffix == '.adsklib']
    return adsklibPaths
def createIcon(zipPath: str):
    iconPaths = []
    basePath = getTempFolder()
    with zipfile.ZipFile(zipPath) as myzip:
        # get png file path
        paths = [f for f in myzip.namelist() if re.search('._png', f) != None]
        for path in paths:
            # open Byte stream
            with myzip.open(path) as img_file:
                img_bin = io.BytesIO(img_file.read())
                img = Image.open(img_bin)
                # get  material id
                path = pathlib.Path(path)
                id = re.sub(r'[\\|/|:|?|.|"|<|>|\|]', '-', str(path.parts[2]))
                iconPath = basePath / id
                # resize
                for width, height in [(32, 32), (16, 16)]:
                    # create icon folder
                    iconPath.mkdir(parents=True, exist_ok=True)
                    savePath = iconPath / f'{width}x{height}.png'
                    clone = img.copy()
                    img_resize_lanczos = clone.resize(
                        (width, height), Image.LANCZOS)
                    # save png
                    img_resize_lanczos.save(str(savePath))
            iconPaths.append(str(iconPath))
    return iconPaths
def getTempFolder():
    folder = pathlib.Path(__file__).parent/'temp'
    try:
        shutil.rmtree(folder)
    except:
        pass
    finally:
        folder.mkdir(exist_ok=True)
    return folder
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            global _handlers
            cmd = adsk.core.Command.cast(args.command)
            inputs = cmd.commandInputs
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            # get adsklib files
            adsklibPaths = getAdsklibPaths()
            # Change to the library of your choice.
            imagePaths = createIcon(adsklibPaths[-1])
            dropdownInput2 = inputs.addDropDownCommandInput(
                'dropdown1',
                'test',
                adsk.core.DropDownStyles.LabeledIconDropDownStyle
            dropdown2Items = dropdownInput2.listItems
            for idx, path in enumerate(imagePaths):
                dropdown2Items.add(
                    f'image{idx}',
                    False,
                    path
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyCommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        adsk.terminate()
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        cmdDef = _ui.commandDefinitions.itemById('Test2')
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition(
                'Test2', 'Test', 'Test')
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
Unfortunately, DropDownCommandInput is too small to tell the difference.
It was very difficult for me.
nnikbin
Hi @kandennti
Thank you so much for providing this nice code.
Unfortunately I have not been able to execute your code yet, because when I run it I receive the following error in Fusion 360 (I have python 3.9.1 and I have installed Pillow using pip)
ModuleNotFoundError: No module named 'PIL'
And VS Code shows:
In addition I do not know how can I associate thumbnails with their appearance names.
I hoped there would be a solution at higher level.
kandennti
nnikbin
@kandennti , You are awesome!
It seems there isn't any direct method at API level for this task.
