Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
2dto 3d
3 REPLIES 3
plagrsm
174 Views, 3 Replies
2dto 3d
Hi guys anyone had any experience adding scrips and add-ons can't get one to work properly can anyone help please
3 REPLIES 3
goyals
in reply to: plagrsm
Can you provide some more information regarding how you are trying and what problem you are seeing?
if there is circle next to add-in in Script dialog, it means that is working.
Normaly it shows new button somewhere in the Toolbar which you can find from the documentation.
Shyam Goyal
Sr. Software Dev. Manager
plagrsm
in reply to: goyals
Hi It's giving me a "hello" notification when I load fusion but can't seem to find a button to make it work on the image I import
goyals
You must have noticed that there are few sample add-ins shipped with Fusion. For example there is an add-in with name SpurGear. When it is run, a command with name 'Spur Gear' is added in Solid->Create menu. Like wise if there are some external developed add-ins, it can be found from its documentation what the add-in supposed to do and how it can be run. Please share any one add-in name you name are trying and not working. Please also share from where you have installed it. I will try it on my side and let you know what I observe.
Shyam Goyal
