Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
2D Trace operation can't be used
1 REPLY 1
karolis.s
106 Views, 1 Reply
I need to create a rest machining in the corner between two planes by using chamfer tool. The only way I know how to do that is by using 2D Trace operation.
Unfortunately, I cannot access its 'CadContours2dParameterValue'..
P.S. if an operation is created by with setup.createFromTemplate method I get same response.
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
import os
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        cam: adsk.cam.CAM = app.activeDocument.products.itemByProductType('CAMProductType')
        setup: adsk.cam.Setup = cam.setups.item(0)
        # create a trace operation input
        input = setup.operations.createInput('trace')
        input.displayName = 'Trace Operation'
        # add the operation to the setup
        trace_op = setup.operations.add(input)
        contour_param = trace_op.parameters.itemByName('contours').value
        # for param in trace_op.parameters:
        #    print(param.name)
        ui.messageBox('Success')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
1 REPLY 1
kandennti
in reply to: karolis.s
Hi @karolis.s -San.
The parameter names seem to be wrong.
        # contour_param = trace_op.parameters.itemByName('contours').value
            try:
                if param.value.classType() == "adsk::cam::CadContours2dParameterValue":
                    app.log(param.name)
            except:
                pass
