Why is one line not visible
RubyRedRick
RubyRedRick
I'm playing with an add-on script to make a sketch of a 2020 extrusion.
I've refactored the code to have a function to draw one quadrant.  It is called four times.  The quadrants are in clockwise  order NE
def makeQuadrant(quadrant,
    sketchLines, sketchArcs, sketchGeometryConstraints,
    xSign, ySign):
    elements = dict()
    lines = []
    posArray = [0,1,2,3,4,5]
    xArray = [0, .225, .55, .55, .31, .31, .85]
    yArray = [.31, .31, .635, .85, .85, 1.0, 1.0]
    firstPoint = adsk.core.Point3D.create(xSign * xArray[1], ySign * yArray[1])
    elements["first_point"] = firstPoint
    lastPoint = adsk.core.Point3D.create(xSign * yArray[1], ySign * xArray[1])
    elements["last_point"] = lastPoint
    for i in posArray:
        startPoint = adsk.core.Point3D.create(xSign * xArray[i], ySign * yArray[i])
        endPoint = adsk.core.Point3D.create(xSign * xArray[i+1], ySign * yArray[i+1])
        if i > 0 & i < 5:
         lines.append(sketchLines.addByTwoPoints(startPoint, endPoint))
    elements["arcStart"] = adsk.core.Point3D.create(xSign * 0.85, ySign * 1, 0)
    elements["arcCenter"] = adsk.core.Point3D.create(xSign * 0.85, ySign * 0.85, 0)
    elements["arc"] = sketchArcs.addByCenterStartSweep(elements["arcCenter"], elements["arcStart"], xSign * ySign * -1.578  )
    for i in posArray:
        startPoint = adsk.core.Point3D.create(xSign * yArray[i], ySign * xArray[i])
        endPoint = adsk.core.Point3D.create(xSign * yArray[i+1], ySign * xArray[i+1])
        if i > 0 & i < 5:
    i = 1
    lines[i].isConstruction = True
    adsk.core.Application.log("{},{},{},{},{},{} isValid {}, isVisible {}, isConstruction {}".format(
            quadrant,
            i,
            lines[i].startSketchPoint.geometry.x,
            lines[i].startSketchPoint.geometry.y,
            lines[i].endSketchPoint.geometry.x,
            lines[i].endSketchPoint.geometry.y,
            lines[i].isValid,
            lines[i].isVisible,
    elements["lines"] = lines
    return elements
The code at the end is for debugging it is intended to show that the second line in each quadrant is the problem child by marking it as construction.  It also shows that that line in each quadrant has different endpoints, so one line isn't on top of another.
Here's the section of the code which calls make quadrant:
# first quadrant
        quadOneElements = makeQuadrant(1, sketchLines, sketchArcs, sketchGeometryConstraints, 1, 1)
        arcCenter = quadOneElements["arcCenter"]
        radialTextPoint = adsk.core.Point3D.create(arcCenter.x + .15,arcCenter.y + .15,arcCenter.z)
        sketchDimensions.addRadialDimension(quadOneElements["arc"],radialTextPoint)
        # second quadrant
        quadTwoElements = makeQuadrant(2, sketchLines, sketchArcs, sketchGeometryConstraints, 1, -1)
        # third quadrant
        quadThreeElements = makeQuadrant(3, sketchLines, sketchArcs, sketchGeometryConstraints, -1, -1)
        # fourth quadrant
        quadFourElements = makeQuadrant(4, sketchLines, sketchArcs, sketchGeometryConstraints, -1, 1)
I'm at my wits end to come up with a theory why that line is missing.
kandennti
Hi @RubyRedRick .
I don't know where you are talking about the line, but I interpreted it to mean this red marked line.
This is because you are trying not to draw it in an IF statement.
    for i in posArray:
        # if i > 0 & i < 5:
            # lines.append(sketchLines.addByTwoPoints(startPoint, endPoint))
The other thing I interpreted was that the endpoints of each line were not in alignment.
If you drag the resulting sketch line, you will see that the endpoints are not aligned.
This is because the Point3D object is used to execute the addByTwoPoints method.
If you want to match endpoints, you must create a SketchPoint in advance and use SketchPoint.
# Fusion360API Python script
import traceback
import adsk
import adsk.core
import adsk.fusion
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root:adsk. fusion.Component = des.rootComponent
        skt: adsk.fusion.Sketch = root.sketches.add(root.xYConstructionPlane)
        skt.isComputeDeferred = True
        make_quadrant(1, skt, 1, 1)
        make_quadrant(2, skt, 1, -1)
        make_quadrant(3, skt, -1, -1)
        make_quadrant(4, skt, -1, 1)
        skt.isComputeDeferred = False
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def make_quadrant(
    quadrant: int,
    sketch: adsk.fusion.Sketch,
    xSign: float,
    ySign: float) -> dict:
    # this side lines
    points = [adsk.core.Point3D.create(xSign * x, ySign * y, 0)
        for x, y in zip(xArray, yArray)]
    sketchPoints: adsk.fusion.SketchPoints = sketch.sketchPoints
    sktPointsThis = [sketchPoints.add(p) for p in points]
    sketchLines: adsk.fusion.SketchLines = sketch.sketchCurves.sketchLines
    linesThis = [sketchLines.addByTwoPoints(p1, p2)
        for p1, p2 in zip(sktPointsThis, sktPointsThis[1:])]
    # other side lines
        for x, y in zip(yArray, xArray)]
    sktPointsOther = [sketchPoints.add(p) for p in points]
    linesOther = [sketchLines.addByTwoPoints(p1, p2)
        for p1, p2 in zip(sktPointsOther, sktPointsOther[1:])]
    # arc
    sketchArcs: adsk.fusion.SketchArcs = sketch.sketchCurves.sketchArcs
    arc: adsk.fusion.SketchArc = sketchArcs.addFillet(
        linesThis[-1],
        linesThis[-1].endSketchPoint.geometry,
        linesOther[-1],
        linesOther[-1].endSketchPoint.geometry,
        0.15
    linesThis.extend(linesOther)
    return {
        'lines': linesThis,
        'arc': arc
You can also use the SketchPoint.merge method to match, but this is easier than finding the other point.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-78a405d9-b50f-4da2-aade-8617a7e37a37
RubyRedRick
No look at the circles. I drew those lines as construction to show I was looking at equivalent lines in each quadrant. All the lines are drawn by the same code. I know about the constraint problem, that’s on the to-do list.B5BFE260-1036-4E46-802B-C764D5A56A1B.jpeg
BrianEkins
It looks like it's a problem with the if statement when you draw the lines. You're using the "&" operator which is a bitwise and where I think you want to "and" which is a logical and. Here's a good description of the difference between the two. https://www.geeksforgeeks.org/difference-between-and-and-in-python/
Here's a modified version of your code that draws the complete shape.
    xSign, ySign):
    elements = dict()
    lines = []
    for i in posArray:
        if i >= 0 and i <= 5:
    for i in posArray:
            quadrant,
            i,
            lines[i].isValid,
            lines[i].isVisible,
    return elements
Brian Ekins
