Why does the view jump upon refresh when the camera position and orientation is not changed?
mike46YZU
mike46YZU
I'm working on a add-in that needs to control the view and ran into unexpected behavior. The test function below updates the view, but does not modify it. Yet, When you change the view manually to some arbitrary viewpoint and then run this function, the view jumps. The orientation remains the same but the view jumps in zoom and pans.
def test():
    app = adsk.core.Application.get()
    view = app.activeViewport
    camera = view.camera
    view.camera = camera
    view.refresh()
    print("test: view has been refreshed...\n")
I need to change the current view without this jump. What am I missing here?
kandennti
Hi @mike46YZU -San.
I tried it and nothing happened.
I knew it would not change anything before I tried it.
There may be a cause other than here, but I can't think of it either.
mike46YZU
I have reproduced this on multiple PC's. Attached is a video. Below is the dedicated Add-In I wrote to demo the issue. Expected behavior is that nothing happens when you run the add-in. Observed behavior is that the view jumps. Note that the view should be changed to a random view from the default one before running the add-in.
# Assuming you have not changed the general structure of the template no modification is needed in this file.
from . import commands
from .lib import fusion360utils as futil
import adsk.core, adsk.fusion
def run(context):
    try:
        # This will run the start function in each of your commands as defined in commands/__init__.py
        commands.start()
        test()
    except:
        futil.handle_error('run')
def test():
    view.refresh()
def stop(context):
    try:
        # Remove all of the event handlers your app has created
        futil.clear_handlers()
        commands.stop()
    except:
        futil.handle_error('stop')
mike46YZU
Video also available here: https://youtu.be/hYu6UPhnGF8
BrianEkins
I'm able to reproduce the problem. I found that it only happens when you have a orthographic (non-perspective) view. But it shouldn't happen then either. I'll see that a bug is logged.
Brian Ekins
