Why does my Script use So much Ram and run So Slow? Is it the Sweeps?
Hi Guys and Girls,
I hope this question is not to basic but I just can not work out why this script runs so slowly and uses so much ram.
The following script creates a single body and performs multiple sweeps in loops.
Disclammer: Its my first day scripting in fusion360 + I am new to python.
Why so much ram (~8 Gb for 100 - 200 sweeps) and why so slow? Is the script fine and this is just how it should be or is there something I could do to speed things up and more importantly increase the number of sweeps I can perform? I only have 16Gb of ram, and was hopeing to be able to do 1000-2000 sweeps in a single script.
kind regards,
Trent
import adsk.core, adsk.fusion, traceback
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
design = app.activeProduct
# Get the root component of the active design.
rootComp = design.rootComponent
# Create a new sketch on the xy plane.
sketches = rootComp.sketches;
xyPlane = rootComp.xYConstructionPlane
sketch = sketches.add(xyPlane)
# Draw two connected lines.
lines = sketch.sketchCurves.sketchLines;
#Create our block
# Draw a rectangle by two points the extrude.
#Define size
halfXSize = 10 #cm
halfYSize = 10 #cm
zSize = 1 #cm
recLines = lines.addTwoPointRectangle(adsk.core.Point3D.create(-halfXSize, -halfYSize, 0), adsk.core.Point3D.create(halfXSize, halfYSize, 0))
# Get the profile defined by the rectangle
prof = sketch.profiles.item(0)
# Create an extrusion input
extrudes = rootComp.features.extrudeFeatures
extInput = extrudes.createInput(prof, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
distance = adsk.core.ValueInput.createByReal(zSize)
extInput.setDistanceExtent(False, distance)
# Create the extrusion
ext = extrudes.add(extInput)
#define shape of holes - circular for testing purposes
# Create sketch cuting holes
#define focalPoint
focalPoint = 20 #distance of focal point from slab = focalpoint - zSize (ie 19)
#Circle
#sketches = rootComp.sketches
#sketch = sketches.add(rootComp.xYConstructionPlane)
#sketchCircles = sketch.sketchCurves.sketchCircles
#centerPoint = adsk.core.Point3D.create(0, 0, focalPoint) # position of "focal point"
#circle = sketchCircles.addByCenterRadius(centerPoint, 0.25)
#prof2 = sketch.profiles.item(0)
#Polygon - no function for polygon in API....ok, from indivifdual lines
line1 = lines.addByTwoPoints(adsk.core.Point3D.create(0, .25, focalPoint), adsk.core.Point3D.create(.2165, .125, focalPoint))
line2 = lines.addByTwoPoints(line1.endSketchPoint, adsk.core.Point3D.create(.2165, -.125, focalPoint))
line3 = lines.addByTwoPoints(line2.endSketchPoint, adsk.core.Point3D.create(0, -.25, focalPoint))
line4 = lines.addByTwoPoints(line3.endSketchPoint, adsk.core.Point3D.create(-.2165, -.125, focalPoint))
line5 = lines.addByTwoPoints(line4.endSketchPoint, adsk.core.Point3D.create(-.2165, .125, focalPoint))
line6 = lines.addByTwoPoints(line5.endSketchPoint, adsk.core.Point3D.create(0, .25, focalPoint))
#draw lines from focal point to other side of  and cut hole along line
#Draw two connected lines.
#factor to adjust the centre of lines from the focal point at the  surface
holeSeparation = 0.8 #cm
#No.of holes each side of centre
xHoles = 2 #cm
yHoles = 3
for i in range(-xHoles,xHoles): #iterate nested loop across all hole positions
for j in range(-yHoles,yHoles):
line1 = lines.addByTwoPoints(adsk.core.Point3D.create(0, 0, focalPoint), adsk.core.Point3D.create(i*holeSeparation, j*holeSeparation, 0)) #Note: add variable for focal point
path = rootComp.features.createPath(line1);
sweeps = rootComp.features.sweepFeatures;
sweepInput = sweeps.createInput(prof2, path, adsk.fusion.FeatureOperations.CutFeatureOperation);
sweep = sweeps.add(sweepInput)
for i in range(-xHoles,xHoles): #Seconf set of loops for when the holes are tessalating polygons
line1 = lines.addByTwoPoints(adsk.core.Point3D.create(0, 0, focalPoint), adsk.core.Point3D.create((i+0.5)*holeSeparation, (j+0.5)*holeSeparation, 0)) #Note: add variable for focal point
sweep = sweeps.add(sweepInput);
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
ekinsb
I don't see any obvious issues with your script.  We need to investigate it on our side to see if there's a problem with the API or within Fusion.  Thanks for reporting this and it looks like you're doing something interesting.
Brian Ekins
Mod the Machine blog
Hi Brian,
Thanks for the fast responce, I just realised that I did not explicidly state that I want to increase the variables xHoles and yHoles from 2 and 3 to the order of 50.
Kind regards,
Trent.
