Visual Studio not launching when selecting edit add-ins
paul.slaterMZZFE
Message 1 of 40
paul.slaterMZZFE
Visual Studio Code will not run when edit is selected. this has become a problem since a Fusion update.
would someone be kind enough to help please?
thanks Paul.
Replies (39)
Message 21 of 40
goyals
Can you try copying the extension from C:\Users\Admin\.vscode\extensions to %USERPROFILE%\.vscode\extensions and see if it works?
Shyam Goyal
Sr. Software Dev. Manager
Message 22 of 40
goyals
Created FUS-78088 ticket to track this issue. We will try to resolve it at the earliest. May be you can try workaround of copying the content of folder from C:\Users\Admin\.vscode\extensions to this location %USERPROFILE%\.vscode\extensions and see if it works for you. Thanks for posting it.
Shyam Goyal
Message 23 of 40
paul.slaterMZZFE
Goyals -I have asked our IT company to do what you have asked and they have said as I am logged in as admin it is the same location?
FYI I have 2 x pc's that are behaving exactly the same and it has happened after a Fusion update to both machines.
Regards Paul.
Message 24 of 40
goyals
ok. Does that workaround help you?
If %USERPROFILE%\.vscode\extensions resolves to C:\Users\Admin\.vscode\extensions on your machine then I am not sure what else is going wrong. I am not aware of anything we changed in this area in last update which should caused this problem if everything was working as expected previously for you. It might be hard for us to resolve the problem until we are able to reproduce the issue on our side. Any I will discuss it in team and get back to you. Thanks.
Shyam Goyal
Message 25 of 40
paul.slaterMZZFE
Goyals -as i mentioned in my last post our IT company said it was the same location, so unfortunately it made no difference.
this problem happened some time ago, maybe from last Sept/Oct i have only just got around to try and fix it because i have a job that requires the functionality. regards Paul.
Message 26 of 40
goyals
I would like to suggest another workaround just in case it might work on your machine. Please try the following script in text command window after switching to python mode.
import sys
sys.path.append(<add the folder path of debugPy module present in ms-python extension on your machine>)
Meanwhile we are investigation this problem on our side.
Shyam Goyal
Message 27 of 40
goyals
Hi @paul.slaterMZZFE ,
I am not able to reproduce this problem on my side so far. Probably you could give a try to following steps
1. Execute the below script in Fusion text command window after switching to python mode.
import sys
sys.path.append(<full path of debugpy folder in ms-python extension directory on your disk>)
This you need to do every time Fusion is restarted so probably not ideal for development activity but may be a quick thing to check if it resolves issue for you.
2. Fusion executes a script, pre-run.py, present in user's app data folder only once per session when user try to edit/debug a script from "Scripts and Add-Ins..." dialog. This script is responsible for installing the extension and adding the path of debugPy module in sys path of Fusion python interpreter.  May be you can edit locatePythonToolFolder function in this file and return the path of debugPy folder on your machine. You should do this step only if # 1 worked for you.
Shyam Goyal
Message 28 of 40
goyals
import sys
Let me know if a zoom screen sharing session is possible. That might help us to understand the problem on your machine. Thanks.
Shyam Goyal
Message 29 of 40
kandennti
I am using Win10 and VSCode does start.
It may be irrelevant, but I am noticing that there is a slight difference from before.
1. Create a new script.
2. Edit the script and start VSCode.
3.Run as debug from VSCode. (It will run.)
4.Quit VSCode once.
5.Delete the ".vscode" folder in the script folder.
6.Start VSCode by editing the script again.
7.It is not possible to run as debug from VSCode.
In the past, even if the ".vscode" folder was deleted, the ".vscode" folder was always copied from somewhere when editing, but in Ver2.0.9719, it is no longer copied.
Message 30 of 40
paul.slaterMZZFE
Kandennti -thank you for your contribution. Obviously I would like to get it running as it was before without all the problems. Regards.
Message 31 of 40
KrisKaplan
FYI: The problem with not re-creating the .vscode folder within a script folder on edit/debug has been fixed and will be in the next update. If you encounter this problem you can just create an empty .vscode folder in your script folder and it will copy the default settings files when launched.
Kris
Kris Kaplan
Message 32 of 40
paul.slaterMZZFE
Kris -thank you, that's good news. I am really busy at the moment so I will wait for the next update where hopefully it will all be working again.
Would you be kind enough to tell me when to expect the update please?
Kind regards Paul.
Message 33 of 40
KrisKaplan
Paul,
This should be in an update set for early March. But if this is the cause of any of your problems, I would not wait for an update to fix it. The trivial workaround would be to just not delete a script's .vscode folder, or to create an empty .vscode folder before using the edit/debug command from the addin manager dialog.
Kris
Kris Kaplan
Message 34 of 40
paul.slaterMZZFE
Hi -I have the latest "early March" update and VScode still does not launch through the API form "edit" or "degug"
Kind regards Paul
Message 35 of 40
I had the same problem. This helped me:
Delete the Python Extension files and the .obsolete file (C:/Users/user name/.vscode/extensions/ms-python.python-20##.###).
Open VS-Code and install the latest Python Extension and "Python for VSCode" (I don't know why, but it works for me).
I honestly don't know if that brings other errors with it.
Hopefully it helps you.
Message 36 of 40
BrianEkins
@paul.slaterMZZFE, Is this working for you now?
Brian Ekins
Message 37 of 40
paul.slaterMZZFE
Hi -thank you for the follow up.
Yes, all working now since an update. Not sure why but not complaining!
Kind regards Paul
Message 38 of 40
jaco.waes
I seem to have the same issue .... suddenly i can no longer link fusion and vscode to debug ... i tried the suggestions from 2 years ago but no luck.
When i click edit, a windows command window opens, it downloads the ms-python and ms-python.debugpy extensions when i had deleted them. But then the windows command window closes and vscode does not open ....
print(sys.path)
['C:\\Program Files\\Autodesk\\webdeploy\\production\\35a60349b112668a59dd7bbcc68b2622875103f4', 'C:\\Program Files\\Autodesk\\webdeploy\\production\\35a60349b112668a59dd7bbcc68b2622875103f4\\Python\\lib', 'C:\\Program Files\\Autodesk\\webdeploy\\production\\35a60349b112668a59dd7bbcc68b2622875103f4', 'C:\\Program Files\\Autodesk\\webdeploy\\production\\35a60349b112668a59dd7bbcc68b2622875103f4\\Python\\lib\\site-packages', 'C:\\Program Files\\Autodesk\\webdeploy\\production\\35a60349b112668a59dd7bbcc68b2622875103f4\\Python\\DLLs', 'C:\\Users\\jaco\\AppData\\Roaming\\Python\\Python311\\site-packages', 'C:/Program Files/Autodesk/webdeploy/production/35a60349b112668a59dd7bbcc68b2622875103f4/', 'C:/Program Files/Autodesk/webdeploy/production/35a60349b112668a59dd7bbcc68b2622875103f4/nspylib.zip', 'C:/Program Files/Autodesk/webdeploy/production/35a60349b112668a59dd7bbcc68b2622875103f4/Api/Python/packages', 'C:/Users/jaco/AppData/Roaming/Autodesk/Autodesk Fusion 360/MyScripts/', 'C:/Users/jaco/AppData/Roaming/Autodesk/Autodesk Fusion 360/MyScripts/Autorun/', 'C:/Users/jaco/AppData/Roaming/Autodesk/Autodesk Fusion 360/MyScripts/Samples/', 'C:/Users/jaco/AppData/Roaming/Autodesk/Autodesk Fusion 360/MyScripts/ProgramData/', 'C:/Users/jaco/AppData/Roaming/Autodesk/Autodesk Fusion 360/MyScripts/AppData/', 'C:/Users/jaco/AppData/Roaming/Autodesk/Autodesk Fusion 360/MyScripts/ManuallyInstalled/', 'C:\\Users\\jaco\\.vscode\\extensions\\ms-python.python-2024.6.0\\python_files\\lib\\python']
import debugpy
Traceback (most recent call last):
File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'debugpy'
What seems strange to me is that even though the debugpy extension gets downloaded, it is not added to the path ...
Message 39 of 40
jaco.waes
If you end up in this older thread using a search this might be your solution.
https://forums.autodesk.com/t5/fusion-api-and-scripts/can-t-edit-or-debug-my-python-scripts/m-p/1275...
Message 40 of 40
jaco.waes
This exact same behaviour has shown up again for me ...  (2.0.19426)
