Vector3d.transformBy(RotationMatrix) does not change vector
    assert(theta >0.0001 and theta < (2.0*math.pi))
    assert(normal.length ==1)
    assert(axis.length ==1)
    r1 = adsk.core.Matrix3D.create()
    r2 = adsk.core.Matrix3D.create()
    r1.setToRotation(theta/2.0, normal, origin)
    ui.messageBox("r1:"+str(r1.asArray()))
    r2.setToRotation(math.pi*2.0 - theta/2.0, normal, origin)
    c1 = axis
    assert(c1.transformBy(r1))
    assert(c1.length >0.0001 or c1.length<-0.0001)
    assert(c1.isPerpendicularTo(normal))
I'm trying to rotate a vector by a user specified angle about a normal to a given plane. Using the rotation matrix functions available.
However this seems to fail because c1 results in the same vector at axis. I'm testing with theta == math.radians(45), a normal of (0,1,0) (y axis) and an axis of (-1,0,0) (reverse x axis)
I would expect the Vector3D.transformBy(Matrix3D) function to compute M*v in and then set v based on homogenized coordinates. Is this not true
Is there an alternative way to compute a vector rotated about an arbitrary axis.
ekinsb
I had a hard time following what you were trying to do in the sample code. Here's a simple example that creates a vector in the X direction and then uses a matrix to rotate it 90 degrees around the Z axis and it returns the correct result.
def vectorTransform():
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        vec = adsk.core.Vector3D.create(1,0,0)
        mat = adsk.core.Matrix3D.create()
        mat.setToRotation(math.pi/2, adsk.core.Vector3D.create(0,0,1), adsk.core.Point3D.create(0,0,0))
        ui.messageBox(str(vec.asArray()))
        vec.transformBy(mat)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
Mod the Machine blog
simon.trendel
It seems the transformBy function does not apply the translational part of the matrix when using Vector3D instead of Point3D, checkout the following simple example:
import adsk.core
def run(context):
    m = adsk.core.Matrix3D.create()
    m.translation = adsk.core.Vector3D.create(0,0,1)
    print(m.asArray()) # (1.0, 0.0, 0.0, 0.0,
                       #  0.0, 1.0, 0.0, 0.0,
                       #  0.0, 0.0, 1.0, 1.0,
                       #  0.0, 0.0, 0.0, 1.0)
    v = adsk.core.Vector3D.create(0,0,0)
    v.transformBy(m)
    print(v.asArray()) # (0.0, 0.0, 0.0)
    v = adsk.core.Point3D.create(0,0,0)
    v.transformBy(m)
    print(v.asArray()) # (0.0, 0.0, 1.0)
Looks like a serious bug to me...
The Matrix implementation exposed by Fusion is fully functional and correct - just very non standard IMO - speaking as someone who is used to graphical Matrix operations such as HTML's canvas or GDI/GDI+
I've written a wrapper over the Matrix class which makes it behave how I expect/need. Feel free to use it as a base for your own or as-is. This code contains a few other choice helpers as well. I call this file "better_types.py" 😉
__all__ = ['Point3D', 'format_point', 'points_eq', 'Matrix', 'ObjectCollectionFromList', 'ObjectCollectionToList', 'ConcatenateObjectCollections']
import adsk.core, adsk.fusion
from numbers import Number
def format_point(point, fmt='{:}'):
  s = '('
  s += fmt.format(point.x)
  s += ', '
  s += fmt.format(point.y)
  if point.z:
    s += ', ' + fmt.format(point.z)
  s += ')'
  return s
def points_eq(p1, p2, epsilon=1e-8):
  if p1 is p2: return True
  if isinstance(p1, adsk.fusion.SketchPoint):
    p1 = p1.geometry
  if isinstance(p2, adsk.fusion.SketchPoint):
    p2 = p2.geometry
  dx = (p1.x - p2.x)**2
  dy = (p1.y - p2.y)**2
  dz = (p1.z - p2.z)**2
  return (dx + dy + dz) <= epsilon**2
def Point3D(x, y, z=0):
  return adsk.core.Point3D.create(x, y, z)
def ObjectCollectionFromList(l):
  oc = adsk.core.ObjectCollection.create()
  for item in l:
    oc.add(item)
  return oc
def ObjectCollectionToList(oc):
  l = []
  for item in oc:
    l.append(item)
  return l
def ConcatenateObjectCollections(l, r):
  for item in r:
    l.add(item)
  return l
class Matrix(object):
  X_AXIS = adsk.core.Vector3D.create(1, 0, 0)
  Y_AXIS = adsk.core.Vector3D.create(0, 1, 0)
  Z_AXIS = adsk.core.Vector3D.create(0, 0, 1)
  ORIGIN = adsk.core.Point3D.create(0, 0, 0)
  def __init__(self, from_matrix=None):
    if from_matrix is None:
      self._m = adsk.core.Matrix3D.create()
    elif isinstance(from_matrix, Matrix):
      self._m = from_matrix._m.copy()
    elif isinstance(from_matrix, adsk.core.Matrix3D):
      self._m = from_matrix.copy()
    else:
      raise 'Invalid transformation matrix type.'
  def as_fusion_matrix3D(self):
    return self._m.copy()
  def copy(self):
    return Matrix(self)
  def identity(self):
    return self
  def translate(self, x_or_point, y=0, z=0):
    if isinstance(x_or_point, Number):
      x = x_or_point
    else:
      x = x_or_point.x
      y = x_or_point.y
      z = x_or_point.z
    m.translation = adsk.core.Vector3D.create(x, y, z)
    self._m.transformBy(m)
    return self
  def rotate_about_x_axis(self, angle):
    """Rotates about the x-axis."""
    m.setToRotation(angle, Matrix.X_AXIS, Matrix.ORIGIN)
    return self
  def rotate_about_y_axis(self, angle):
    """Rotates about the y-axis."""
    m.setToRotation(angle, Matrix.Y_AXIS, Matrix.ORIGIN)
    return self
  def rotate_about_z_axis(self, angle):
    """Rotates about the z-axis."""
    m.setToRotation(angle, Matrix.Z_AXIS, Matrix.ORIGIN)
    return self
  def scale(self, x=1, y=1, z=1):
    a = [x, 0, 0, 0,
         0, y, 0, 0,
         0, 0, z, 0,
         0, 0, 0, 1]
    m.setWithArray(a)
    self.multiply(m)
    return self
  def reflect_about_yz(self):
    """Reflects through the X axis about the YZ plane."""
    return self.scale(-1, 1, 1)
  def reflect_about_xz(self):
    """Reflects through the Y axis about the XZ plane."""
    return self.scale(1, -1, 1)
  def reflect_about_xy(self):
    """Reflects through the Z axis about the XY plane."""
    return self.scale(1, 1, -1)
  def multiply(self, other):
    self._m.transformBy(other)
    return self
  def purify(self):
    a = self._m.asArray();
    b = []
    for i in range(16):
      if abs(a[i]) < 1e-15:
        b.append(0)
      elif abs(abs(a[i]) - 1) < 1e-15:
        if a[i] < 0:
          b.append(-1)
        else:
          b.append(1)
      else:
        b.append(a[i])
    self._m.setWithArray(b)
    return self
  def transform(self, x_or_points, y=0, z=0):
    """Transforms a list of points, a single point, or a literal x,y,z
    and returns a new list of, or single, transformed point(s).
    Args:
      x_or_points: May be a list of points, a single point, or a number representing 'x'.
      y: y cord
      z: z cord
    if isinstance(x_or_points, list):
      new_points = []
      for p in x_or_points:
        b = p.copy()
        b.transformBy(self._m)
        new_points.append(b)
      return new_points
    if isinstance(x_or_points, Number):
      b = Point3D(x_or_points, y, z)
    else:
      assert isinstance(x_or_points, adsk.core.Point3D) or isinstance(x_or_points, adsk.core.Vector3D)
      b = x_or_points.copy()
    return b
