Utilizing native command definitions
Hi all,
I have some questions regarding the usage of native command definitions with API.
1. I wish to 'feed' inputs to native command definitions with API to reduce manual operations. Take the 'Interference' command as an example, I want to select all bodies and accept the default solution in ALL cases. Therefore, I would like to automate this process by feeding the input (All bodies, then click 'Compute') to the 'Interference' command using API.
From what I have learnt from the documentation, limited command definitions support API inputs in the form of 'Custom Name Values'. However, this information is very limited and I wish to obtain more guide on this.
2. Regarding the native command definitions, is there any possibility that users will be able to customize them to better suit our use? As an example, I wish to customize the 'Fluid volume' command to try to cap the openings automatically or inform users the location of openings.
All discussions will be appreciated!
