Using cast to further code hints autocompletion
hpekristiansen
hpekristiansen
In  the section "Code Hints" here:
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-743C88FB-CA3F-44B0-B0B9-FCC378D0D782
it can be read, that casting can be used to enable VSC to make code hints. Can someone please explain how and when to use this methode? - I would like as many hints as possible.
In this minimal extrusion code:
import adsk.core, adsk.fusion
app = adsk.core.Application.get()
ui = app.userInterface
doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
design = app.activeProduct
rootComp = design.rootComponent
extrudes = rootComp.features.extrudeFeatures
sketch = rootComp.sketches.add(rootComp.xYConstructionPlane)
circles = sketch.sketchCurves.sketchCircles
circle = circles.addByCenterRadius(adsk.core.Point3D.create(0, 0, 0), 5.0)
profile = sketch.profiles.item(0)
extrudes.addSimple(profile, adsk.core.ValueInput.createByReal(5), adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
.rootComponent
in
is not hinted. -and it makes no difference, if I use
or
design = adsk.fusion.Design.cast(app.activeProduct)
What is the advantage of the cast version?
Is there a way to make the hints work for everything?
.extrudeFeatures
.sketchCurves
.sketchCircles
Right now, it is not working for me.
kandennti
Hi  hpekristiansen.
Spyder worked well with Intellisense when using casts.
Since becoming VSCode, I feel that "python.autoComplete.extraPaths" in [settings.json] works well.
Also, if you use Type Hint introduced from python3.5, ".sketchCurves" will also work with IntelliSense.
I think other properties and methods will work as well.
Nilesh.Mohite
Hi @hpekristiansen ,
In addition to @kandennti reply,you can further refere to following post for verifying your settings of python def files(for OSX)
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/code-hints-in-visual-studio-code-howto/m-p...
Lets us know if you need further help.
Nilesh Mohite
LinkedIn
If my answer helped you, please use  ACCEPT SOLUTION .
Also be generous with Likes!  Thank you and enjoy!
