User Command Preview does not work, execute does.
adminTCYL2
adminTCYL2
I have done a nice little skript to generate Ropes, Coils and Cords along a users curve:
By now the script works only after pressing "OK". As seen in the montage-picture, the User should see what his settings do while the settings-window is opened. But he sees the result only after pressing Ok and thereby closing this window. This is, because the  Class "MyInputChangeHandler" does not work right. But it is not written by me and I am confused. I wrote a boolean named "execute" into line 35. The MyInputChangeHandler sets this to False, so the rest of the skript is only done by MyExecuteHandler. Otherwise it tries to make previews, but this leads to failures.
Can someone help me to improve this skript? I want to give it for free to the Autocad Website:
import adsk.core, adsk.fusion, adsk.cam, traceback, os, math
# Global variables to keep them referenced for the duration of the command
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
_handlers = []
_dropdownInput3 = adsk.core.DropDownCommandInput.cast(None)
_inputs = adsk.core.CommandInputs.cast(None)
def makeIt(execute):
    try:
        # Here is my code that is done with every change in User-Selections:
        # Get UserCommand-Values
        curve = _inputs.itemById('selection').selection(0).entity
        broadness = _inputs.itemById('broadness').value
        thickness = _inputs.itemById('thickness').value
        rotations = _inputs.itemById('rotations').value
        shape = _dropdownInput3.selectedItem.name
        design = _app.activeProduct
        root_comp = design.rootComponent
        # create new component
        # newOcc1 = rootComp.occurrences.addNewComponent(adsk.core.Matrix3D.create())
        # root_comp = newOcc1.component
        # root_comp.name = 'Windings'
        path = root_comp.features.createPath(curve)
        planes = root_comp.constructionPlanes
        planeInput = planes.createInput()
        distance = adsk.core.ValueInput.createByReal(0)
        planeInput.setByDistanceOnPath(path, distance)
        #execute = True
        if execute:
            plane = planes.add(planeInput)
            sketches = root_comp.sketches
            sketch = sketches.add(plane)
            # Define lines for linear profiles
            point1a = sketch.sketchPoints.add(adsk.core.Point3D.create(broadness, 0, 0))
            point1b = sketch.sketchPoints.add(adsk.core.Point3D.create(-broadness,0, 0))
            point2a = sketch.sketchPoints.add(adsk.core.Point3D.create(0, broadness, 0))
            point2b = sketch.sketchPoints.add(adsk.core.Point3D.create(0,-broadness, 0))
            line1 = sketch.sketchCurves.sketchLines.addByTwoPoints(point1a, point1b)
            line2 = sketch.sketchCurves.sketchLines.addByTwoPoints(point2a, point2b)
            if shape == 'Rope': loops = 2
            else: loops = 1
            for p in range (0,loops):
                #create the correct sweep witch edge is used as Path.
                if p==1:
                    prof = root_comp.createOpenProfile(line1, False)
                else:
                    prof = root_comp.createOpenProfile(line2, False)
                sweeps = root_comp.features.sweepFeatures
                sweepInput = sweeps.createInput(prof, path, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
                sweepInput.twistAngle = adsk.core.ValueInput.createByReal(rotations*math.pi*2)
                sweepInput.isSolid = False
                sweep = sweeps.add(sweepInput)
                lastBody = root_comp.bRepBodies.count-1
                body = root_comp.bRepBodies.item(lastBody)
                body.isLightBulbOn = False
                loop = 2
                if shape == 'Coil': loop = 1
                for k in range(0, loop):
                    if k ==0: edge = body.edges.item(1)
                    else: edge = body.edges.item(3)
                    twist = 0
                    # The edge of the flat sweep is now used as path for the solid sweeps
                    path1 = root_comp.features.createPath(edge, False)
                    planeInput.setByDistanceOnPath(path1, distance)
                    plane1 = planes.add(planeInput)
                    sketches1 = root_comp.sketches
                    sketch1 = sketches1.add(plane1)
                    circle1 = sketch1.sketchCurves.sketchCircles.addByCenterRadius(adsk.core.Point3D.create(0,0,0), thickness/2)
                    prof1 = sketch1.profiles.item(0)
                    # create solid sweep
                    itemIndex1 = root_comp.bRepBodies.count
                    sweepInput1 = sweeps.createInput(prof1, path1, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
                    sweepInput1.twistAngle = adsk.core.ValueInput.createByReal(twist)
                    sweepInput1.isSolid = True
                    sweep = sweeps.add(sweepInput1)
            # Here is my code that is additionaly done when User presses OK:
            _ui.messageBox("your Selection was: Shape: "+shape + ", Broadness: "+ str(broadness)+ ", Thickness: "+ str(thickness)+", Rotations: "+ str(rotations))
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# Event handler for the inputChanged event.
class MyInputChangedHandler(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            eventArgs = adsk.core.InputChangedEventArgs.cast(args)
            changedInput = eventArgs.input
            execute = False
            makeIt(execute)
        except:
            if _ui:
# Event handler for the execute event.
class MyExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            execute=True
            makeIt(execute)
        except:
            if _ui:
# Event handler for the destroy event.
class MyDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        adsk.terminate()
# Event handler for the commandCreated event.
# Here you create your UserCommands
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            eventArgs = adsk.core.CommandCreatedEventArgs.cast(args)
            global _inputs
            _inputs = adsk.core.CommandInputs.cast(eventArgs.command.commandInputs)
            message = '<div align="center">See also my <a href="http:picsandpixels.at/windings">windings-AddIn</a></div>'
            _inputs.addTextBoxCommandInput('fullWidth_textBox', '', message, 1, True)
            selInput = _inputs.addSelectionInput('selection', 'Select open curve', 'SketchCurves')
            selInput.setSelectionLimits(1)
            selInput.addSelectionFilter('SketchCurves')
            global _dropdownInput3
            _dropdownInput3 = _inputs.addDropDownCommandInput('dropdown3', 'shape', adsk.core.DropDownStyles.LabeledIconDropDownStyle)
            _dropdownInput3.listItems.add('Cord', False, '')
            _dropdownInput3.listItems.add('Rope', True, '')
            _dropdownInput3.listItems.add('Coil', False, '')
            _inputs.addValueInput('broadness', 'Broadness', 'mm', adsk.core.ValueInput.createByReal(0.4))
            _inputs.addValueInput('thickness', 'Thickness', 'mm', adsk.core.ValueInput.createByReal(0.2))
            _inputs.addIntegerSpinnerCommandInput('rotations', 'Rotations', 0, 20, 1, 10)
            # Connect to command execute.
            onExecute = MyExecuteHandler()
            eventArgs.command.execute.add(onExecute)
            _handlers.append(onExecute)
            # Connect to input changed.
            onInputChanged = MyInputChangedHandler()
            eventArgs.command.inputChanged.add(onInputChanged)
            _handlers.append(onInputChanged)
            # Connect to the command terminate.
            onDestroy = MyDestroyHandler()
            eventArgs.command.destroy.add(onDestroy)
            _handlers.append(onDestroy)
        except:
            if _ui:
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui  = _app.userInterface
        # Create a command.
        cmd = _ui.commandDefinitions.itemById('tableTest')
        if cmd:
            cmd.deleteMe()
# Rename the script in the following line:
        cmd = _ui.commandDefinitions.addButtonDefinition('tableTest', 'Cord, Rope, Coil -Maker', 'Table Test', '')
        onCommandCreated = MyCommandCreatedHandler()
        cmd.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmd.execute()
        # Set this so the script continues to run.
        adsk.autoTerminate(False)
    except:
        if _ui:
kandennti
Hi @adminTCYL2 .
For preview, use the executePreview event instead of the inputChanged event.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-dbecfaf8-9bb6-4e40-9df3-0a3e48136a4b
I modified it like this, and it works correctly.
    def __init__(self):
        super().__init__()
        try:
            # changedInput = eventArgs.input
            # execute = False
            # makeIt(execute)
        except:
            if _ui:
    def __init__(self):
        super().__init__()
        try:
            onExecutePreview = MyExecutePreviewHandler()
            eventArgs.command.executePreview.add(onExecutePreview)
            _handlers.append(onExecutePreview)
class MyExecutePreviewHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        eventArgs = adsk.core.CommandEventArgs.cast(args)
        execute = True
        makeIt(execute)
Items created by the executePreview event will be deleted on their own without the need to delete them.
adminTCYL2
Yes! It works. Thank you kanndenti,
I cleaned the code a bit, to put it here as an example for a working user selection.
_handlers = []
def makeIt():
    try:
        broadness = _inputs.itemById('broadness').value/4
        thickness = _inputs.itemById('thickness').value/2
        rootComp = design.rootComponent
        root_comp.name = 'CordRopeCoil'
        #path = adsk.fusion.Path.create(curve,1)
        # #see https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-1728AD08-743F-4ABB-AA10-C2B2C53A0757
        else: loops = 1
            if p==1:
            else:
            loop = 2
                twist = 0
                #_ui.messageBox("your Selection was: Shape: "+shape)
    except:
        if _ui:
    def __init__(self):
        super().__init__()
        makeIt()
    def __init__(self):
        super().__init__()
        try:
            makeIt()
        except:
            if _ui:
    def __init__(self):
        super().__init__()
        adsk.terminate()
# Here the your UserCommands are created
    def __init__(self):
        super().__init__()
        try:
            global _inputs
            message = '<div align="center">See also my <a href="http:picsandpixels.at/fusion360">windings-AddIn</a></div>'
            _inputs.addValueInput('broadness', 'Broadness', 'mm', adsk.core.ValueInput.createByReal(0.2))
            _inputs.addIntegerSpinnerCommandInput('rotations', 'Rotations', 0, 50, 1, 10)
        except:
            if _ui:
def run(context):
    try:
        global _app, _ui
        # Create a command.
        if cmd:
            cmd.deleteMe()
        cmd.execute()
    except:
        if _ui:
