Use certain sketch in Fusion360 for Pipe by code
rocco.mayr
rocco.mayr
I created a sketch in Fusion 360 and now I want to use this sketch in my code to create a pipe.
I have this base code:
def run(context):
    _ui = None
    try:
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        design = _app.activeProduct
        # Get the root component of the active design.
        rootComp = design.rootComponent
        # create sketch
        crv = initSktCircle(rootComp)
        # create pipe
        initPipe(crv)
def initSktCircle(comp :adsk.fusion.Component):
    skt :adsk.fusion.Sketch = comp.sketches.add(comp.xYConstructionPlane)
    pnt3D = adsk.core.Point3D
    crvs :adsk.fusion.SketchCurves = skt.sketchCurves
    crv = crvs.sketchCircles.addByCenterRadius(pnt3D.create(-5.0,-5,0), 4.0)
    return crv
def initPipe(path):
    sels :adsk.core.Selections = _ui.activeSelections
    sels.clear()
    sels.add(path)
    txtCmds = [
        u'Commands.Start PrimitivePipe', # show dialog
        u'Commands.SetDouble SWEEP_POP_ALONG 1.0', # input distance
        u'Commands.SetDouble SectionRadius 0.5', # input radius
        u'NuCommands.CommitCmd' # execute command
    for cmd in txtCmds:
        _app.executeTextCommand(cmd)
    sels.clear()
Now how could I bring my sketch in the code? I tried:
crv = rootComp.sketches.item(0).sketchCurves.sketchCircles
# create pipe
initPipe(crv)
kandennti
Hi @rocco.mayr .
Processed for all circles in the specified sketch.
# Fusion360API Python script
import traceback
import adsk.cam
import adsk.fusion
import adsk.core
_app: adsk.core.Application = None
_ui: adsk.core.UserInterface = None
def run(context):
    global _app, _ui
    try:
        # create pipe
        for crv in rootComp.sketches.item(0).sketchCurves.sketchCircles:
            initPipe(crv)
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def initPipe(path):
    global _app, _ui
    sels: adsk.core.Selections = _ui.activeSelections
    sels.clear()
    sels.add(path)
    txtCmds = [
    for cmd in txtCmds:
    sels.clear()
rocco.mayr
Works Thx.
What also works is:
crv = rootComp.sketches.item(0).sketchCurves.sketchCircles.item(0)
initPipe(crv)
