Update drawing references
ianjwellings
Message 1 of 8
ianjwellings
I'm trying to update a drawing using the updateAllReferences method as follows:
app = adsk.core.Application.get()
drawing = adsk.drawing.Drawing.cast(app.activeProduct)
drawing.updateAllReferences()
The command fails with the following attribute error:
AttributeError: 'Drawing' object has no attribute 'updateAllReferences'
Does anyone know if I'm missing something in the code?
Have also tried:
active = app.activeDocument
active.updateAllReferences()
Thank you
Replies (7)
Message 2 of 8
Rushikesh.kadam
@ianjwellings
This is something the team has worked on and will be supported in one of the upcoming Major releases.
Below code will work in that release.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 8
kandennti
Hi @ianjwellings .
Try this.
# Fusion360API Python script
import traceback
import adsk.core
import adsk.drawing
def run(context):
    ui = None
    try:
        ui  = app.userInterface
        cmdDef: adsk.core.CommandDefinition = ui.commandDefinitions.itemById(
            'FusionDocUpdateCommand'
        cmdDef.execute()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
@ianjwellings .
Will they enhance Draw next to enhance CAM?
That is something to look forward to.
Message 4 of 8
ianjwellings
Ok thank you for the update
Message 5 of 8
ianjwellings
Thank you for this - it worked great.  Do you know if there is also a command to export the drawing as a dxf file?
Message 6 of 8
kandennti
@ianjwellings .
Unfortunately, the API does not provide much functionality for Drawing, so the only thing that can be exported is PDF.
Message 7 of 8
ianjwellings
This command works perfectly for updating the drawing.  I would like to run another function after this command is executed however the function runs before this command has finished.  Is it possible to wait until the drawing update command is finished and then call an export_drawing() function?
def update_drawing():
    ui = None
    try:
        cmdDef: adsk.core.CommandDefinition = ui.commandDefinitions.itemById('FusionDocUpdateCommand')
        cmdDef.execute()
        ####WAIT FOR COMMAND TO FINISH###
        export_drawing()
    except:
        if ui:
Message 8 of 8
kandennti
@ianjwellings .
If you want to perform an update in the middle of a process, you can do so by doing the following.
    ui = None
    try:
        # ui  = app.userInterface
        # cmdDef: adsk.core.CommandDefinition = ui.commandDefinitions.itemById('FusionDocUpdateCommand')
        # cmdDef.execute()
        app.executeTextCommand(u'Commands.Start FusionDocUpdateCommand')
        # export_drawing()
    except:
        if ui:
