Tutorial crashes
Tutorial crashes
eric
Tutorial crashes
eric
I went to here
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-3922697A-7BF1-4799-9A5B-C8539DF57051
The code "Basic Add-in Command" Crashes when run, please see the attached image.
Any ideas where I could get a example of creating a basic add in command which does not crash?
marshaltu
The error message said the icons for your command were missing. Its path was "./Resources/Sample". Unfortunately we didn't put those icons into the page to download.
You may have to create icons by yourself or copy existing icons to the folder to make the addin work. You can probably find some icons under C:\Users\<User>\AppData\Local\Autodesk\webdeploy\production\<GUID>\Python\AddInSamples\AddInSample\resources .
Marshal
Marshal Tu
Fusion Developer
JeromeBriot
another quick solution is to remove the folder path from the addButtonDefinition command:
        # Create a button command definition.
        buttonSample = cmdDefs.addButtonDefinition('MyButtonDefIdPython',
                                                   'Python Sample Button',
                                                   'Sample button tooltip',
Then the menu appears without the icon.
