Trouble with radial dimension
casey.rogers
Alumni Alumni
casey.rogers
I have the following code that attempts to create a radial dimension:
        offsetB = sketch.sketchDimensions.addRadialDimension(outerCircle, outerC.geometry)
        offsetB.parameter.expression = someExpression
I keep getting an error that offsetB.paramter is a noneType object and has no attribute expression. I am trying to use the radial dimension in the same way I'd use a length dimension, is that incorrect? Why is the parameter a noneType object?
ekinsb
I just wrote the simple test below and it's working correctly for me.  I don't see anything obviously different from your code.
        des = app.activeProduct
        root = des.rootComponent
        sk = root.sketches.add(root.xYConstructionPlane)
        circles = sk.sketchCurves.sketchCircles
        circle1 = circles.addByCenterRadius(adsk.core.Point3D.create(0, 0, 0), 2)
        dims = sk.sketchDimensions
        radDim = dims.addRadialDimension(circle1, adsk.core.Point3D.create(2.2, 2.2, 0))
        radDim.parameter.expression = "4 in"
Brian Ekins
Mod the Machine blog
casey.rogers
Well I tried your test code and it failed as well, I identified the issue: I was working in the direct modeling environment. Capturing design history fixed it.
