Transformation on occurrence getting reset?
JesusFreke
JesusFreke
I've been experimenting with the API a bit, and have run into a strange problem.
I've created a minimally reproducible example here: https://hastebin.com/dataxefizi.py
It creates a sphere as a new component, and then sets the component's occurrance's transform.
And then, it creates another sphere as another new component, which seems to reset the transformation on the first sphere.
The first print on line 34 prints "-5.0", while the second print on line 37 prints "0.0".
Why is the transformation on the first component's occurrence getting reset in this case?
masounmardini
The problem is the last line of sphere def
you refer to item 0
BrianEkins
My guess is that the position of the component is being reset.  It's the same as in the UI when you see this dialog, except with the API, it's not displaying the dialog and is resetting everything to its previous position.
Before creating the next occurrence, you can add the code below, which will capture the current position in a snapshot and then it won't move back. "des" is a reference to the currently active Design.
des.snapshots.add()
Brian Ekins
JesusFreke
you refer to item 0
Thanks for taking a look! I don't think that's it though. Since the revolve feature is using
NewComponentFeatureOperation, feature.parentComponent should be a new, separate component, and root.allOccurrencesByComponent should return a list with a single item, containing the single occurrance of the new component. I added some logging to my previous example and confirmed that this was the case.
JesusFreke
BrianEkins, that did the trick, thanks!
Here's the updated, working example, for posterity 🙂
import adsk.core, adsk.fusion, adsk.cam, math, traceback
app = adsk.core.Application.get()
root = adsk.fusion.Design.cast(app.activeProduct).rootComponent
design = adsk.fusion.Design.cast(app.activeProduct)
def sphere(radius) -> adsk.fusion.Occurrence:
    sketch = root.sketches.add(root.xYConstructionPlane)
    center_point = adsk.core.Point3D.create(0, 0, 0)
    start_point = adsk.core.Point3D.create(radius/10.0, 0, 0)
    arc = sketch.sketchCurves.sketchArcs.addByCenterStartSweep(center_point, start_point, math.pi)
    sketch.sketchCurves.sketchLines.addByTwoPoints(arc.startSketchPoint, arc.endSketchPoint)
    revolves = root.features.revolveFeatures
    revolve_input = revolves.createInput(sketch.profiles.item(0), root.xConstructionAxis,
                                         adsk.fusion.FeatureOperations.NewComponentFeatureOperation)
    angle = adsk.core.ValueInput.createByReal(math.pi)
    revolve_input.isSolid = True
    revolve_input.setAngleExtent(True, angle)
    feature = revolves.add(revolve_input)  # type: adsk.fusion.Feature
    return root.allOccurrencesByComponent(feature.parentComponent)[0]
def run(context):
    ui = None
    try:
        first = sphere(10)
        transform = first.transform
        transform.translation = adsk.core.Vector3D.create(-5, 0, 0)
        first.transform = transform
        design.snapshots.add()
        print(first.transform.translation.x)
        second = sphere(10)
    except:
        print(traceback.format_exc())
