Timeline doc inconsistency
MichaelT_123
Advisor Advisor
MichaelT_123
Hi TF360,
Could you look at … the SMALL documentation problem/inconsistency.
Based on the documentation – page Timeline.item Method
returnValue = timeline_var.item(index)
returnValue is of type TimelineObject
It is not always the case.
It could also be of the type: TimelineGroup.
The issue propagates into page TimelineObject Object where:
propertyValue = timelineObject_var.entity    # = timeline_var.item(index).entity
based on documentation should
“Returns null if this is a TimelineGroup object"
It is not the case.
Attempt to get entity property from TimelineGroup object generates error:
“    return _fusion.TimelineObject__get_entity(self)
RuntimeError: 3 : Associated feature is invalid.”
Regards
MichaelT
MichaelT
Rushikesh.kadam
@MichaelT_123 Thank you for reporting the case. I have created a ticket and assigned it to the concerned team.
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
