Tessalate feature api/ surface body support
vytska4301
vytska4301
Trying to tessalate surface bodies with the tessalate feature gives an error, while the tessalate command succesfully tessalates the same surface body, which makes me think that the funtionality is there, but there is an exception that prevents using it through api.
Here is the error i get:
File "C:\.../Api/Python/packages\adsk\fusion.py", line 69867, in createInput
return _fusion.TessellateFeatures_createInput(self, bodies)
RuntimeError: 3 : Only solid bodies are supported.
zozeorswaf
Radwan-Almsora
In the Autodesk Fusion API, the TessellateFeatures.createInput() method explicitly requires solid bodies and does not natively accept surface bodies. Because the interactive GUI command supports surface bodies, this discrepancy is a known API limitation.
To resolve your issue, you can enter here.
BRepCoEdge.body Property
How to convert a surface body to a solid body in Autodesk Fusion
Cannot tessellate solid or surface body to create mesh body" when using Tessellate command in Fusion...
Convert a solid body to a mesh body
Radwan-Almsora
don't forget to click the Accept Solution button and leave a < like !
@Radwan-Almsora - this post has been edited due to Community Rules & Etiquette violation.
