template path in API local
TRIALCAD2014
TRIALCAD2014
I'm trying the new operation sample in the documentation https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-AEF0708D-B657-4E9F-9032-4535E0D1C417
my template manager tells me that my templates are stored under Local//my templates yet the documentation uses an absolute  path
path = "E://face.f3dhsm-template";
that does not match with how the product displays it.
how can I programatically get the /Local path?
Thank you,
Adrian
kandennti
Hi @TRIALCAD2014 .
I created a function to get the default template folder in the Win version.
# Fusion360API Python script
import traceback
import adsk.cam
import adsk.fusion
import adsk.core
import pathlib
import json
def run(context):
    ui: adsk.core.UserInterface = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        path = get_CAM_Templates_Default_Folder_Path()
        if len(path) > 0:
            msg = f'The default template folder is \n {path}'
        else:
            msg = 'The default template folder was unknown.'
        ui.messageBox(msg)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def get_CAM_Templates_Default_Folder_Path() -> str:
    pathsJson = json.loads(app.executeTextCommand(u'paths.get'))
    tmpPath = pathlib.Path(pathsJson['userDataDirectory'])
    folder = tmpPath.parent.parent / 'CAM360' / 'templates'
    if folder.is_dir():
        return str(folder)
    else:
        return ''
However, if I were to create an add-in that uses CAM templates, I would export the templates beforehand and place them in the add-in folder to be called.
This way, the file is more secure and less likely to be modified.
TRIALCAD2014
Thank you for your helpful reply. I was expecting a method in the manufacture API to do that instead of using a round about way with textcommands.
I did manage to get it directly from Os with
localPath=os.path.dirname(os.path.abspath(__file__))+"\\..\\..\\..\\..\\CAM360\\templates\\"
    boxCountourTemplateFilename = localPath+"b box contour.f3dhsm-template"
    pauseTemplateFilename = localPath+"b box pause.f3dhsm-template"
but your way seems to be more appropriate.
Thank you for the smart suggestion of putting the template in the scripts path. That would make my solution much simpler because will require just a os.path.abspath(__file__)) call
I'm thinking to make this plugin public so maybe it's simpler for the users to use the default. The templates will be better user created to match their machines. It's  little bit of grasping at the straws as the cam API is so inexistent that operations created with the templates will be invalid anyway.
Thank you
Adrian
    drillTemplateFilename = localPath+"b box drill.f3dhsm-template"
