Take screenshot based on paraments.
11:52 PM
Hi, I am working on a script in fusion 360 API which takes fbx and obj files, where the requirement is the input parameter should be angle change in the object, size change in the object, different colors in the object, sunlight effect, or light effect. For each parameter change, it should take a capture image function(screenshot).
So can you give me suggestions or generate( Write script) based on the above description?
