SYSTEM ERROR ==> getAsCoordinateSystem()
MichaelT_123
Advisor Advisor
MichaelT_123
This "simplified" script results in a system error.
The code is:
transform_tmp = adsk.core.Matrix3D.create()
(returnValue, origin, xAxis, yAxis, zAxis) = transform_tmp.getAsCoordinateSystem()
The error is:
SystemError: <built-in function delete_Point3D> returned a result with an error set
Is there something wrong with mine code ... or in the system's core?
Regards
MichaelT
MichaelT
KrisKaplan
Unfortunately, this is a problem with the documentation.  The return type from getAsCoordinateSystem is 'void' (as is visible from the C++ tab of the documentation).  Void returns are never assigned to variables, so the sample code line should be:
(origin, xAxis, yAxis, zAxis) = matrix3D_var.getAsCoordinateSystem()
Your sample should run if you remove the 'returnValue' variable from the tuple you are assigning into.  We will update the documentation for this (and similar) case(s).
Kris
Kris Kaplan
MichaelT_123
Thank you Mr. Kaplan,
... it works now ... like a spell of Wiedźmin of Oz !!!
With Regards
MichaelT
PS. ... and there is some strange synergy here, ... your name means 'Priest'  in slavic languages ( Kapłan in polish language),  Wiedźmin word is based on Sanskrit word Veda which means knowledge (  wiedza in slavic languages ). Smiley Happy
MichaelT
ekinsb
Just to let you know that I've fixed this in the help system and it will be corrected when the Fusion update goes live later this week.
Brian Ekins
Mod the Machine blog
MichaelT_123
Appreciated !!!, Mr. Ekins
MichaelT
KrisKaplan
Thanks.
Interesting.  My ancestry is (paternally) Polish.  My understanding is that at some point it was shortened from something like Kaplanowski.
Kris
Kris Kaplan
